D-series Throttle body question help plzzz
Old Feb 27, 2011 | 08:22 PM
javifunksEK's Avatar
Default D-series Throttle body question help plzzz
i just recently did auto to manual swap everything came out perfect i just got a manual throttle body for the manifold where those the hose under the throttle body lead too... d16y8 btw
Old Feb 27, 2011 | 08:33 PM
Former User's Avatar
Default Re: D-series Throttle body question help plzzz
Inclusion of some punctuation in your text would help members understand what you need.
Old Feb 28, 2011 | 03:51 AM
Libertariat's Avatar
Ek Forever y0!
Indeed, I've got no idea what you're trying to say.
Old Feb 28, 2011 | 03:57 AM
grumblemarc's Avatar
The Grumpiest
Apparently there are some hoses from the TB that he needs to know where they attach to.
Old Feb 28, 2011 | 09:22 AM
KK let me rewritte this because i was in a rush when i did this.... I recently did an auto to manual swap on my d16y8. Everything came out perfect and a couple of days ago i swap the intake manifold to a manual one , the throttle body also but there is two hoses under the throttle body where do those hoses go...
Old Feb 28, 2011 | 09:25 AM
Those two hoses likely go to the IACV. The auto IACV is attached to the bottom of the throttle body. The manual IACV is attached to the back of the intake manifold.
What year Civic and what year IM/TB?
Old Feb 28, 2011 | 09:53 AM
is a 96. But the iacv has already two hoses connected which are the cooling hoses the go under the iacv...
Old Feb 28, 2011 | 10:52 AM
apexi_rsx's Avatar
the valve under the TB is a FITV for cold starting. you can leave it unhooked or hook it up inline with your IACV on the back of the intake manifold. one hose goes to the nipple on the passengers side of the intake manifold going through the head and the other hose that would come from the IACV on the back of the manifold to the pipe that runs across the back of the water pump to the thermostat housing has a nipple.
Old Feb 28, 2011 | 11:14 AM
The 96 Civic does not have a FITV.
Old Feb 28, 2011 | 11:16 AM
i forgot to mention im running an auto throttle body with a manual intake manifold is that the reasond im getting bad hesitation...
Old Feb 28, 2011 | 08:10 PM
bbb
DarkDaysX6
Jul 9, 2013 05:53 PM
miamihonda
May 6, 2012 10:28 AM
perseverance
Nov 27, 2006 03:57 PM
perseverance
Nov 26, 2006 04:32 PM
JRDbuilt
Mar 13, 2005 03:08 PM
