k20a2 crx swap
Been searching but no luck so far. What do I need for a k20a2 swap into a crx si? Obviously engine, tranny, ecu, engine wiring harness, axles, cable to hydro tranny adapter, shift linkage. But what jumper harness do I use?
If you plan on going kpro right away go with rywire, if not go with hybrid racing there harness has both o2 sensor wired into harness rywire does not, also the hybrid harness has a obd2 port to scan, k-swap are not cheap nor is kpro but kpro is the way to go and does no matter what harness
No haven't looked at h22 cuz I can get a 03 k20a3 full engine with tranny, ecu, wiring harness, intake and axles for 500 bucks. Wonderin how hard it would be to swap into my crx. Other wise I'm goin ls/vtec
Stop talking. K series is leaps and bounds over an H series.
If your going to do a K do not bother with a an A3. Stick with K20A, A2, Z1 or Z3
Wow... LOL!
PWNED!
if you have complete harness for k20 why do you need a harness to make the engine work in the chassis of an ef....any help would be great i understand the mounts and the axles i got that part the trouble im having is the wiring im confused about that my buddy is a honda tech i just need to know what i need to get
Liquidgsr
Nov 2, 2008 01:56 PM
