just put in gas for the first time, and care won't start. backfired. =\
Old Feb 26, 2011 | 02:26 PM
vptran1's Avatar
Default just put in gas for the first time, and care won't start. backfired. =\
so i have a del sol with a b18c type r in it. i put super premium into the car.
the car just came out of the shop and was running perfectly. i stopped by to get gas, i tried to turn on my car after and the exhaust backfired, i heard a gunshot like noise coming from there. i tried again and it was there again but was a lot more soft. now i just hear farting sounds coming from my car.
anybody know whats wrong with it?
what can i do. help please.!
Old Feb 26, 2011 | 03:28 PM
EJeff8's Avatar
Default Re: just put in gas for the first time, and care won't start. backfired. =\
Does your engine have anything on it that causes it to need a high octane gas?
I'm thinking you just over saturated the engine with too much octane...
Old Feb 26, 2011 | 05:44 PM
vptran1's Avatar
the guy that sold me the car said he always got super premium on it.
i just check 3 hours later. ran the car and it turned on.
but i have a feeling the samething might happen.
what could be wrong?
Old Feb 26, 2011 | 05:47 PM
EJeff8's Avatar
If that engine is stock, it does not need that high of an octane fuel. It's backfiring because you have unburned gas in the cylinders. The reason it won't start, I can't say now, since the last owner apparently used SP all the time. Any CELs?
Old Feb 26, 2011 | 05:52 PM
Eddie 70's Avatar
LOL!!! Really.
Old Feb 26, 2011 | 06:09 PM
EJeff8's Avatar
You wanna say something of substance? Kid said he filled it up with SP and it stopped. I assumed a possibility would be that there was too much unburned fuel in his cylinders and it caused the engine to backfire and to be too flooded to have a constant idle. Say something that'll help the kid, ***.
Old Feb 26, 2011 | 06:25 PM
Eddie 70's Avatar
I didn't mean to make you call me an ***, really. I just thought your answer of "I'm thinking you just over saturated the engine with too much octane... " was one of those answers I read on here all the time. Just like my answer, not much substance. High octane gas just burns slower and helps a higher compression motor resist knock. Just putting the gas in his car did not, in my opinion cause the car to back fire. There has to be something else wrong there. Maybe timing, IDK.
Here are a few facts I pulled about high octane gas.
Octane Facts
• Knock occurs when cylinder pressures are high. It is normal for an engine to ping a little at full throttle
because cylinder pressures are very high at full throttle. Engine knock, however, should not be ignored
since it can result in serious damage to the engine.
• High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when
• If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in
switching to higher octane gasoline.
• If your engine knocks or pings, it does not necessarily mean something is wrong with the gasoline. It could
be a problem with the engine’s electronic control systems, ignition timing or exhaust gas recirculation. On a
high mileage engine, a carbon build-up in the cylinders can increase cylinder pressures and cause knock.
• Almost all of today’s new cars have fuel-injected engines that need to use gasoline with a detergent additive.
They do not necessarily need high octane gasoline with a detergent additive. Generally, new automobiles
need high octane gasoline only if the manufacturer recommends it.
• Always follow the auto manufacturer’s octane recommendations in your owner’s manual.
Octane Myths
• High octane gasoline improves mileage.
In general, if your car is designed to run on 87 octane gasoline, high octane gasoline will not improve
mileage. If switching to high octane gasoline does improve mileage, you might find that your engine, or its
control systems, need repair.
• High octane gasoline gives quicker starting.
No, it doesn’t.
• High octane gasoline increases power.
If your car is designed to run on 87 octane gasoline, you shouldn’t notice any more power on high octane
gasoline. Again, if it does make a noticeable difference, your engine, or the engine’s electronic control
systems, may need repair.
• High octane gasoline has been refined more – it is just a better product.
Additional refining steps are used to increase the octane; however, these additional steps do not necessarily
make the gasoline a “better” product for all engines. They just yield a different blend of hydrocarbons that
burn more slowly. The additional steps also increase the price.
Old Feb 26, 2011 | 06:34 PM
vptran1's Avatar
the engine isnt stock. i have a b18c type r swap in there.
shouldnt i fill it with SP? the guy did, not sure how many problems he had with it.
Old Feb 26, 2011 | 06:36 PM
vptran1's Avatar
CELs? im sorry im really new to cars
Old Feb 26, 2011 | 06:47 PM
Eddie 70's Avatar
CEL Check Engine Light
Here is how to check for the codes.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Feb 26, 2011 | 07:04 PM
EJeff8's Avatar
Glad we could clear that up. I've just seen a lot of noobs think that buying the highest fuel available is going to make their engine run great, and it won't. Too high of an octane fuel for an engine without the right compression isn't good for it. So, while my point could be a reach, it could be a possibility, albeit one on the edge.
Old Feb 26, 2011 | 07:06 PM
vptran1's Avatar
no check engine. =\
i hope that i wont encounter that problem again.
i hope it was just a one time thing, but im sure it wont just go away like nothing.
Old Feb 26, 2011 | 07:10 PM
EJeff8's Avatar
Wait, so your car is fine now? I thought you said it wouldn't start anymore? This would've been helpful at the beginning.
Old Feb 26, 2011 | 07:49 PM
vptran1's Avatar
i said i tried 3 hours later after i posted this.
i randomly reattempted.
but im sure its gonna happen again.
Old Feb 26, 2011 | 08:14 PM
gwl's Avatar
gwl
I would try to put in the same gas that gave you the same problem. If the problem comes back then you know it is the gas. Even though you don't have a CEL, you should check the timing. Back in the 80's when I had my 79 Celica, my car would stink when I used Shell gas. I could never figure that out.
Old Feb 26, 2011 | 08:57 PM
delsizzle1's Avatar
double check timing not only on the timing belt but on the distributor, check if the spark plug wires are where they are supposed to be, double check your injectors are plugged in correctly, double check your main relay which is underneath the steering wheel in the left kick panel, make sure all the relays are plugged good... and u can proly even just double check your plugs that are in it too may not be the right ones..
Old Feb 26, 2011 | 08:59 PM
delsizzle1's Avatar
and you can also check that your ecu is all plugged in correctly too could be that it isnt. or it could be a ghetto rigged swap, just sayin... ive came across alot of em
Old Feb 26, 2011 | 09:44 PM
vptran1's Avatar
alright thanks for the input guys. i appreciate it
Old Feb 27, 2011 | 02:02 AM
First.EG's Avatar
check your main relay my car would not start at random after i changed the relay it never happened again
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
almostboostedgsr
Mar 26, 2007 10:57 AM
StraightCivic
May 15, 2006 05:07 AM
JDMlyfestyle
19
Jan 7, 2004 08:16 PM
