New Cometic B18 LS Turbo Head Gasket
Got this and can not use it GET IT CHEAP!
Paid $140 for it shipped, it is 2.5mm or .098" thick! 81.5mm bore
crack head price of $105+Shipping FIRM!!!
Its 5 layers 3 are .010" rubber coated both sides and 2 are solid stainless steel not mild steel that will rust.
Drop this on your B18A or B and drop the compression to 8.3:1 on stock internals.
Only Opened to take Pics
eBay auction I bought it from
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
forged internals are dependent on manufacture basically this drops your factory CR from 9.5 to 8.3 so if the pistons you have are for instance 10:1 CR subtract 1.2 off the CR
Then you would be looking at 7.8-8.3:1
This is a rough estimate as we all know when you add items like flat face valves or polish the combustion chambers change anything including milling the head it will effect the CR
