J-swap eg hatch
Old Feb 26, 2011 | 01:46 AM
svtford4x4's Avatar
Default J-swap eg hatch
I am looking for anything jswap related, motors seem readily available in all of their different variations. I understand transmissions can be a little harder to find, I was not able to come up with much for automatic mounts. Also need to do some research on the immobilizer, drive by wire, and any other fun electrical surprises involved. Not too worried about the hood clearance issue.
An added plus is the previous owner hacked up the pass. side motor mount so I'm fine with starting fresh there.
Any input is a plus, even links to threads i might have overlooked.
Thanks for reading.
Old Feb 26, 2011 | 04:35 AM
92lxsleeper's Avatar
Default Re: J-swap eg hatch
just grab the entire accord its coming from and you'll have most everything you need including wiring. just use an older 3.0 vtec throttle body so you can keep the cable.
Old Feb 26, 2011 | 05:22 AM
grumblemarc's Avatar
The Grumpiest
http://www.j32a.com/
Old Feb 26, 2011 | 08:38 AM
EFPhilly's Avatar
Look at the hasport mounts that are adjustable, you can run the engine low and get hood clearance, or high and get ground clearance....
Old Feb 26, 2011 | 08:53 AM
NotAJDMFanBoy's Avatar
Anything adjustable seems to have issues with keeping in place...not sure how Hasport would do this though to keep them adjusted correctly.
Old Feb 27, 2011 | 02:27 PM
EFPhilly's Avatar
Honda tuner did an article not too long ago about the mounts. Ill see If I can dig up the issue to see if they gave any sights for more information. The mounts are used on a lot of the top drag cars with J-swaps, so I dont think they have a problem staying in place, maybe on boosted applications. All the cars features were running N/A with NOS at most.
Old Feb 27, 2011 | 02:33 PM
JDM-sol 89's Avatar
x2
Honda tuning had a very nice article on different motors/ trans plus a very well detailed guide on the swap itself. Try finding a copy of the magazine from a buddy or buy it offline. Def worth it IMO.
Old Mar 1, 2011 | 09:41 PM
svtford4x4's Avatar
I was looking for odyssey power trains, but the accord is a better choice? I am wondering if an automatic is out of the question or not.
when the mounts were on the lower setting it looked like ground clearance was non-existent, also have some fab work experience but i realize hasport has it down to a science
i just ordered a subscription to honda tunning after i read the article about jswap online first mag arrived today xD
Old Mar 1, 2011 | 09:47 PM
EFPhilly's Avatar
Yeah the lowest setting has no ground clearance and that is why they are running slicks. Personally I would get ground clearance and make a hood scoop thing. **** its a V6 not a 4 cylinder anymore so ppl cant dog on the scoop. lol.
I dont see why ppl cant get enough power out of the K though....and be happy lol.
Old Mar 4, 2011 | 02:08 AM
svtford4x4's Avatar
my idea was to build a cowl induction hood off the existing hood keeping the same line.
Old Mar 4, 2011 | 09:58 AM
EFPhilly's Avatar
Oh that would look nice. Going to use angel hair to blend it?
Old Mar 4, 2011 | 10:09 AM
Evs-One's Avatar
Solbros Owns Me
j32a.org is going to be your best bet. I quit giving out information once people kept hounding me for every last detail....but a lot of info is over there :thumbsup:
Old Mar 4, 2011 | 10:35 AM
sleeper98civic's Avatar
http://www.hmotorsonline.com/shop/sc...age&item=30035
There web site says their out of stock but looks like it comes with almost every thing you would need.
Old Mar 4, 2011 | 10:46 AM
del_sol_freak's Avatar
J32a.com, K20a.org, b20vtec.com. All these websites have good info. The automatic mounts have to be custom fab'd. car-part.com is your friend when doing this swap.
Not trying to thread jack here is a pic of the J32a2 swap I am doing. I have hasport EGJ2in the high position for referance. A small cowl is doable.
Old Mar 4, 2011 | 03:03 PM
Jdmpopper's Avatar
Pm don from rpm I'm sure he can answer any questions Or help I'm sure. His Honda tech name is rpm systems.
Old Mar 6, 2011 | 07:05 PM
fracas's Avatar
RPM's cars (Cowl inside)
http://www.j32a.com/showthread.php?t=841
swap looks good. I have a 97 Del Sol I just shaved and painted and Im also dropping in a j32
Blazin Si
Apr 11, 2005 05:34 AM
JDMotive
Jun 19, 2004 05:59 PM
93HatchCali
Sep 14, 2003 12:00 PM
JohnnyM
Jul 10, 2003 08:14 PM
43MA
Feb 27, 2003 08:31 PM
