Replaced Ball Joints and noise is still there.
Old Feb 25, 2011 | 08:29 PM
SIDreamer's Avatar
Default Replaced Ball Joints and noise is still there.
I replace ball joints on my 95 civc after hearing groaning, creaking noise after an axle change. I did that today and when I took of the noise was still there. Can this be a defective axle? Thanks
Old Feb 25, 2011 | 08:39 PM
NeonPinHead's Avatar
Default Re: Replaced Ball Joints and noise is still there.
bearing perhaps. jack the car up in the front and support with stands then check for noise while you rotate the wheels
Old Feb 25, 2011 | 08:48 PM
SIDreamer's Avatar
I did that as well no noise when car is raised. noise comes when accelerating from a stop or breaking to a stop or going up a bump slowly.
Old Feb 25, 2011 | 08:49 PM
SIDreamer's Avatar
Noise was not there before I changed the axle
Old Feb 25, 2011 | 09:28 PM
double check every bolt you touched to make sure you didn't leave anything loose.
lopezchris21
14
Aug 10, 2008 06:57 PM
Hyb
Jun 7, 2005 02:49 PM
ghettols
14
Aug 15, 2003 12:52 PM
td04civic
Feb 6, 2002 05:44 AM
