Intermittent wiper ?
Old Feb 24, 2011 | 05:57 PM
same ol Steve's Avatar
Default Intermittent wiper ?
The intermittent wipers on my 91 Civic Si have started working on the initial turn on of the switch but not again after the first swipe. Do any of you have any ideas where I should start my search to fix them? They work fine on the 2 regular settings.
TIA
Old Feb 28, 2011 | 04:51 PM
DAP91Si's Avatar
Default Re: Intermittent wiper ?
I have the same problem and suspect it is something called the Integrated Control Unit. It controls the wiper relay as well as the flashers, seatbelt, key on and brake warnings. It is located under the dash. The dealer doesn't sell them anymore. I think it is like the main relay were a re-soldering job may solve the problem.
Old Feb 28, 2011 | 05:52 PM
lazlong's Avatar
^ Are you sure it's not the switch itself?
Old Feb 28, 2011 | 07:43 PM
96Formula6spd's Avatar
yeah thats the icu. Change it out. Mine was bad with the same problem. Tho I had bad wiring and had now wipers at all.
Old Feb 28, 2011 | 08:58 PM
subgeniusdude's Avatar
I wasnt aware EF's had an ICU,I know DA's do.Just replace the capacitors that are known to leak,cheap and easy fix as long as the circuit paths havent been eaten away by the leaky caps.See the link for details:
http://forums.g2ic.com/showthread.ph...or-less-than-5
Old Feb 28, 2011 | 10:27 PM
ghosthatch's Avatar
ive noticed this on mine sometimes
Old Mar 1, 2011 | 12:51 AM
CaliforniaBear's Avatar
It happens to me too. I turn my wipers on all the way, let'em go crazy for a little while and then turn it back to inter and it usally works lol
miahmouse
28
Oct 24, 2014 07:21 PM
TylerC161
Apr 25, 2007 12:57 PM
Feuerraeder
Audio / Security / Video
Mar 15, 2002 06:43 AM
