What causes this....
Old Mar 14, 2002 | 07:13 PM
Feuerraeder's Avatar
Default What causes this....
This might be the wrong forum to ask in, but I'll give it a shot. I have a set of fog lamps made by pilot. If you don't know Pilot, they're pretty run of the mill with a relay and fuse and all. Anyway, when I turn them on I hear a strange clicking noise from the relay, and no light coming from the lamps. Do I have a bad ground somewhere, or is the relay just shot? I've tried almost everything short of replacing all the wiring.
Old Mar 14, 2002 | 07:30 PM
89 CRX SI's Avatar
Default Re: What causes this.... (civicdisobedience)
well the relay should click only once if it clicks several times then you got either a bad realy or bad relay holder. See a relay is a mechanical switch. When electricity is applied it switches over. So when you are applying electricity the realy is switching back and forth. GET A NEW REALY. If that doesnt work the you have a Voltage problem. Uo dont have enough voltage into the relay. IM or e-mail me anymore questions you have
Old Mar 14, 2002 | 07:40 PM
Default Re: What causes this.... (89 CRX SI)
Yeah, it clicks rapidly until i click the switch off. I'll goto autozone and get a relay tommorow, hopefully that's the problem.
Old Mar 14, 2002 | 07:44 PM
89 CRX SI's Avatar
thatll be your problem did the relay come with the kit?? If it didnt then thats your problem cause you got the wrong one.
Old Mar 15, 2002 | 06:43 AM
No, It came with the kit, they used to work, but one day I opened my hood to find thing
jooky5
Oct 23, 2018 05:59 PM
dalek
Dec 26, 2007 12:21 PM
DeviousCTR
Jun 28, 2006 03:43 PM
JDMdamian95
May 1, 2006 09:45 PM
