Would skunk2 base map cause high emissions?
Old Feb 24, 2011 | 06:51 AM
sleepydragon636's Avatar
Default Would skunk2 base map cause high emissions?
i got a b18c1 motor and p72 ecu. the guy i brought it from told me he put a skunk2 base map on. i got high grose polluter readings on hc and high readings on co. new cat installed.
Old Feb 24, 2011 | 06:56 AM
Default Re: Would skunk2 base map cause high emissions?
timing was at 10 degrees, but when i put it back to 16 degrees the car now puts out more black smoke... most likely running more rich.
Old Feb 24, 2011 | 07:34 AM
1998GsRIntegra's Avatar
Is the motor stock? If not what is done to it?
Usually all ecu chips and maps not specifically done for your modifications are over richened stock maps. If your motor is stock, get a stock ecu.
Old Feb 24, 2011 | 11:10 AM
it seems stock, the guy i brought it from said he put in itr pison and crank but i think it was all bs. i'll buy a stock ecu and put it in, hopefully it wont be as rich.
Old Feb 24, 2011 | 12:23 PM
VegasInvasion's Avatar
I'm Huge In Japan
All you need to do is buy a new chip on eBay. Don't worry, you should be able to blow that motor in no time dude.
Old Feb 24, 2011 | 12:24 PM
Yea if its stock, use a stock ecu. There is no advantage to using a modified fuel table on a stock motor, unless it was tuned by someone in person on a dyno. You could probably pick up 5-8 hp by having it dyno tuned.
In your case, use a stock ecu until you can get a real tuneable ecu and buy some dyno time. Best of luck to you.
Old Mar 5, 2011 | 04:05 PM
i put a stock ecu in and set the timing to 16 btdc. my hc readings are now around 200 in 15mph and 25mph... everything else is good. any suggestions??? im putting a new o2 on next week to see.
Sr420Det
Engine Management and Tuning
Mar 21, 2010 09:50 PM
RacinMasonC
Nov 10, 2007 07:01 PM
b16a4
Jan 22, 2007 02:19 PM
noob with an RS
Nov 11, 2004 11:56 AM
