H23A1 crankshaft pulley bolt!
Old Feb 23, 2011 | 11:12 PM
iponnet's Avatar
Default H23A1 crankshaft pulley bolt!
silly question but which way does this loosen? I know I know, but thought better safe than sorry! I've read online the honda engines with the timing belt on the left side loosen clockwise and my 96 prelude si has the timing belt on the left side so...?
Also if I put the transmission in 1st gear will it hold the engine while I try to loosen the crankshaft bolt or do I really have to just get the special holder for these engines?
thanks in advance,
Old Feb 24, 2011 | 12:25 AM
iponnet's Avatar
Default Re: H23A1 crankshaft pulley bolt!
my crankshaft turns counterclockwise normally does this mean it will loosen clockwise? tx
Old Feb 24, 2011 | 03:04 AM
dagle's Avatar
yeah, if it's the opposite way it's usually marked/labeled with an arrow indicating it.
So for the crank pulley, it's still righty tighty, lefty loosey. otherwise i'm surprised my crank never spun the pulley off ( i just impacted the bolt on)
Old Feb 24, 2011 | 04:36 AM
carnot's Avatar
The threads on the crankshaft pulley bolt are normal right handed threads. I would purchase the special crankshaft pulley holder.....I never had luck by putting the transmission in 5th and trying the break the bolt loose....too much give in the whole system.
01celica_gts
Jul 15, 2007 09:12 AM
freshley
Jun 26, 2006 01:19 PM
Yolandita
May 21, 2006 06:54 PM
EKB18BPR3
Jan 8, 2004 11:18 AM
jdmbike
Feb 20, 2002 09:19 AM
