Transmission & Drivetrain Gearboxes, Differentials, Clutches
itr countershaft vs b16 countershaft
Old Feb 23, 2011 | 09:19 PM
88 EF Hatch's Avatar
Default itr countershaft vs b16 countershaft
Are there any differences in the 95-97 spec jdm itr countershaft and 00 si countershaft? Reason I ask is I plan on running a type r lsd with a 66 teeth ring gear and want to make sure that my 15 tooth si countershaft will work. From my reasearch a 95-97 itr and gsr ring gear is 66 teeth and their countershafts are 15 teeth, which gives it a 4.4 final drive. So will my 15 tooth b16 countershaft work? And I'm a noob at this, is the countershaft the same as a pinion? Thanks for help
Old Feb 23, 2011 | 09:57 PM
Aquafina's Avatar
Default Re: itr countershaft vs b16 countershaft
What's the P/N? Should be the same but not sure.
Buy a new countershaft or use the countershaft that belongs to the ITR ring gear.
Old Feb 24, 2011 | 07:31 AM
How do I check part #? Is there one on my b16 countershaft?
KyleVA
May 13, 2006 07:44 AM
strsi
13
Mar 28, 2005 10:51 AM
crazy eyez killa
Nov 24, 2003 09:01 AM
RTW DC2R
Feb 26, 2003 10:13 AM
