cel code 17 wont go away!
Old Feb 23, 2011 | 03:08 PM
Love-MY-honda's Avatar
Default cel code 17 wont go away!
i had a cel code 17 on my 1999 b16 so i replaced my vss with a brand new one from autozone and cel code poped up again and my speedo still wont work. please help.
Old Feb 23, 2011 | 04:58 PM
Default Re: cel code 17 wont go away!
bump
Old Feb 23, 2011 | 05:57 PM
C'mon on now someone has to know.
Old Feb 23, 2011 | 07:53 PM
ej1916's Avatar
You check your wiring? Check the plugs to see if its corroded? Could be the cluster. ECU could be a possibility. Check all the fuses?
Old Feb 23, 2011 | 08:28 PM
i do have a bad cluster. could that really send a cel code to the ecu? It is a 99 SI.
Old Feb 23, 2011 | 09:20 PM
kyosoeg6's Avatar
first of all if the cluster is bad and you knew that why did u waste money on a vss and not buy a working cluster?
you could have just had a friend help you out and switch your vss to his car to see if it works instead of buying a new one. do you know whats wrong with your cluster?
Old Feb 23, 2011 | 09:31 PM
Mr. EG's Avatar
Check for corrosion on the engine harness side of the connector. Check the wiring also.
Old Feb 23, 2011 | 11:00 PM
virgineg6's Avatar
never heard of a bad cluster throwing a CEL, but does your VTEC engage? cuz if it does then your vss is working properly and its just your cluster that needs to be replaced. why do i ask if VTEC engages because VTEC requires a signal from your vss to function properly among others. if it doesnt then theres corrosion at the connector or you have a broken wire or a loose pin in the system.
Old Feb 24, 2011 | 11:22 AM
i dont have anyone who has a vss for a honda. all my friends are nissan fanboys... other wise i would of. And yes my vtec does engage. so that must mean theres a short somewhere right? and is there a way to directly wire the vss to the ecu and if so how bad would that be or would it make no difference.
Old Feb 24, 2011 | 11:28 AM
back to your question... everything on my cluster works except for speedo and rpms. thing is its never given me a cel cod 17 because of that.
Old Feb 24, 2011 | 11:43 AM
EJeff8's Avatar
^Cluster could have been intermittent, wiring to the VSS could have finally worn down or shorted somewhere, causing the ECU to assume it was the VSS. Not trying to be mean, but you wasted money buying the wrong part when you obviously knew another piece in the circuit was bad.
Old Feb 25, 2011 | 08:44 AM
hatmanafro's Avatar
greeting from the integra section. lol
i seem to have the same problem on my 1990 integra. everything in my cluster works fine. the sensor seems to be working fine and since my car is kinda old i dont think there is a plug that goes to the speed sensor. could there be any other reason as to why it could be throwin that code?
or should i just reset the ecu?
Old Feb 25, 2011 | 08:56 AM
EJeff8's Avatar
^Find a friend and swap cluster and VSS real quick to see which one acts up. If neither, check your wiring.
GhostBoy99
Apr 28, 2019 01:17 PM
Love-MY-honda
14
Dec 23, 2010 07:36 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
Suck my DX
Nov 1, 2006 08:10 AM
07
10
Apr 4, 2005 10:02 AM
