failed emmissions
Old Feb 23, 2011 | 01:44 PM
SR20S13's Avatar
Default failed emmissions
so i went to take my 95 civic hatchback with a B18c1/b16 head to get the emissions done today and well it failed HC and CO it passed with FLYING colors but NOx it failed pretty bad
HC 200=fail i got 58
CO 1.07 was fail and i got 0.02
NOx= 2333 and i got 2747
so what the hell can i do i burn alot of oil think it could be be a clogged cat mabye? could running some seafoam through the engine fix it maybe run alot of octane booster so less fuel is burnt and NOx goes down?
or just get my exhaust welded up with the new high flow cat and be done with it?
Old Feb 25, 2011 | 11:43 AM
letank's Avatar
Default Re: failed emmissions
Nox is usually due to very high combustion temperatures, such as a lean condition, defective EGR -if you have one-
you can enter all the numbers, especially the CO2 and O2 into the lambda calculator at this site.
http://www.smogsite.com/calculators.html
Going thru the same stuff.
Old Feb 27, 2011 | 12:25 PM
PyroProblem's Avatar
If I understand your post right, try adding a little more fuel. That should bring the nox down. CO might come up a little bit too, but should stay below the max limit...
92civicfreak
50
Dec 3, 2007 03:03 PM
wi_accord
Apr 11, 2006 05:56 PM
mintscorpion
19
Jan 20, 2006 04:27 PM
headhunter
Oct 29, 2002 02:54 PM
