Trans Or Linkage Issues???!!!
i have a 97 civic HX with an LS motor with GS-r trans.. for some odd reason about two days after i started driving it 2nd gear went away..all it does is make a horrible grinding noise and every now and then i can get it into gear. but now i cant get it into first anymore! its doing the samething for first. the trans was purchased off of ebay with reciepts of a total rebuild. theres also alot of play in the shifter itself. Can someone help with this being its my daily!
thankx guys.... yea one night i was riding and everything but 2nd was fine and i parked my car woke up the next morning and 1st didnt work...i also had this problem with a d series trans in an EJ....is there a little troll haunting me stealing my gears?!
wut im saying is the trans was good then all of a sudden overnite it just broke.... is there anything else that it could be.... i changed all the bushings last night and theres no more play in the shifter but i still cant get a gear
Trans needs to come apart, if it's just first and second it wont go into i'd say you've got a bent/broken 1st/2nd shift fork, broken synchro spring or bad sleeve/hub/gear.
Did you let anyone else drive the car without you in it? Off the top of my head, I'd say it was a bad re-build and you should hit up Ebay about a refund/exchange.
thankx guys. im guessing my daily is going to down for awhile...anyone know where to get a gs-r trans lol...damn i hate driving the ole ladys escort!!!!!
ok guys something new is going on......i finally got my car on level ground and i clutched in and put it in reverse and while i was still clutched in my car started to move in reverse by itself!!! i hit the brakes to stop it and i let off the brakes and it started moving slowly backwards...WUT THE HELL IS GOING ON!?
any specs on torque for the clutch and pressure plate? its a F1 lightweight flywheel and an exedy stage 1 clutch
blackedEk
Transmission & Drivetrain
Jul 23, 2011 12:26 AM
one slow coupe
Jun 28, 2005 04:10 PM
