Transmission & Drivetrain Gearboxes, Differentials, Clutches
clicking lsd
Old Feb 22, 2011 | 12:41 PM
c1teg's Avatar
Default clicking lsd
i baught a jdm lsd b16 tranny from a fulla for a parts tranny. he told me that the lsd was makin a clicking noice like an axle while turning corners and before he took it out it started to do it ina straight line. also before he took it out he replace the two axles and it still did it. i believe he said he used crappy tire axles and sometimes they click from new. i got it and braught it home and split the case and found that the two diff bearings were ****ed. i took the gears out and jus sat the diff in its place and spun it and the bearings roared like a bastard. i also found the magnet had a bit of filings and a few little peices of metal about the size of the tip of a bic pen on it but everything else looked to be fine. my buddy is a mechanic and he said that the filings would have came from the bearings because they r quite bad. so im wonderin if the bad bearings would make that kinda noice or is the diff actually ****ed. its a clutch type lsd and i counted the teeth on the ring gear and got that its a 4.4 fd. heres a few pics of the diff
Old Feb 22, 2011 | 01:31 PM
94EG8's Avatar
Seagull Management
Default Re: clicking lsd
Either that's not your diff or 88 EF Hatch stole your pics.
Old Feb 22, 2011 | 01:32 PM
Aquafina's Avatar
Bearings need to be replaced. Filings are from lots of stuff in the trans, sliders are probably worn out. Take the diff apart and inspect the gears and clutch plates. I'd be concerned about the small pieces (bic tip size).
EDIT: 94EG8 I noticed that too. I noticed the speed limit sign appears to be in MPH, I figured since he is in Canada it would be in KM/H.
Old Feb 22, 2011 | 01:48 PM
c1teg's Avatar
yes ur right its his diff but the same one, i thought i mentioned that in the first post.
the bearins were real bad, i believe they changed a seal on one side cause the seal is all **** eyed (shoved in to the bearing on one side and out in place on the other) and the bearing face was all shoved in against the bearings and loose so im hopin its a peice of the bearing cage or somethin simple like that.
is it a big job to take the lsd apart and check it over
Old Feb 22, 2011 | 03:39 PM
Aquafina's Avatar
Not a big job, you just have to know what you're looking at and be sure to reassemble it correctly.
Old Feb 22, 2011 | 04:07 PM
c1teg's Avatar
jus went down in the shop and looked it over and found that the gears inside the lsd r all chewed to hell. is there a rebuild kit i can get for it and how much would it be or is ita right off
Old Feb 22, 2011 | 04:13 PM
Aquafina's Avatar
Contact a dealer for the LSD and find out. Likely cheaper to replace it entirely.
Old Feb 22, 2011 | 04:43 PM
c1teg's Avatar
heres a few pics of the actual unit. thought it was the same but is not
Old Feb 22, 2011 | 04:54 PM
94EG8's Avatar
Seagull Management
Bigger pics would help, I can tell it's an LSD, but that's about it.
mhewitt
Dec 8, 2008 12:09 AM
PrecisionH23a
Apr 29, 2006 09:29 AM
LSegHatchy
Apr 13, 2005 11:45 AM
98oRange
Apr 8, 2005 06:45 PM
OldSchoolSwap
Mar 6, 2003 07:23 AM
