swapping blown d15b7 w/d15z1
Old Feb 22, 2011 | 11:32 AM
civiclover88's Avatar
Default swapping blown d15b7 w/d15z1
i have a 93 civic dx with a blown d15b7 i bought a d15z1. i planned on using the dizzy alt from the b7 on z1 but the dizzy doesnt line up. i read on this swap an seen a couple people were having trouble with some wiring problems. im jus wondering what i have to do to make this a successful swap.
Old Feb 23, 2011 | 07:19 AM
bladesz42's Avatar
Default Re: swapping blown d15b7 w/d15z1
well the z1 is a vtec engine so your non vtec dizzy is not going to line up if im correct, your going to need a vtec d series dizzy and for the wiring, you wont have the plugs for vtec so you wont have to plug it in (no problems there) but they are both obd1 so everything else should line up. your going to need to change your ecu from the p06 to the p07 aswell. good luck with the swap
HondaPartsHero
181
Jul 13, 2019 03:04 PM
boostwhat
Nov 26, 2008 12:31 PM
IOWAb16TEG
Jun 23, 2007 08:45 PM
EMFinite
Apr 28, 2007 12:19 PM
