Ignition fuse keeps blowing! please help.
Old Feb 21, 2011 | 05:20 PM
91sedan_kid's Avatar
Default Ignition fuse keeps blowing! please help.
Okay so i have a 1993 honda civic ex bone stock. i woke up today and tried to warm up my car for work but it wouldnt start.
The car drove fine last night but this morning i got in and turn the key to the on position and all the lights came on. Then i tried to start the car and it wouldnt crank, as if it had a dead battery, i tried to start it once more and all the dash light went out. Checked all my fuse and the IG 50A fuse in the fuse box in the engine bay was blown. Bought two new ones and replaced it. Tried to start the car and it blew the fuse again.
Has anyone ever had this problem or know any reason why this problem is occuring?
any help is much apperciated.
Old Feb 21, 2011 | 05:27 PM
ej2kiid's Avatar
Default Re: Ignition fuse keeps blowing! please help.
check the wiring? if everything is good
porbably a short circuit
Old Feb 21, 2011 | 05:36 PM
Former User's Avatar
Does the fuse only blow when the key is turned to ON(III)?
Old Feb 21, 2011 | 05:44 PM
ej2kiid's Avatar
same happen to me but it was on my fog lights
problem was my ground wire was fudged uppp
Old Feb 21, 2011 | 11:50 PM
problem solved!
on the starter there is a plug and a nut. the part where the plug wire plugs into came loose and was touch the starter case. got it back into place and car started right up.
Old Aug 11, 2023 | 11:38 PM
alishalynn's Avatar
This sounds similar to our car problem! It flashes green light cranks starts for a second then dies. Keys are programmed. Mechanics and locksmiths either think they know how to fix and are wrong or have no idea. Clear spray paint was smashed in the door the day before. A mechanic ran a diagnostics and a D-2 code popped up (see pic)
if you can help I’d appreciate it.
ayeelsee@gmail.com
Old Jan 19, 2025 | 09:13 PM
karanguraya's Avatar
ayeelsee@gmail.com
did you fix this problem can you help me out i am stuck with same problem
Colby Schwedes
Honda Ruckus and Scooters
May 31, 2019 06:02 PM
mike03,95civic
Dec 31, 2008 08:11 AM
#1 Dominican
Dec 27, 2008 12:50 PM
vnguyen850
Mar 4, 2007 07:53 AM
MeanGreenEG9
May 6, 2003 05:02 AM
