does anyone have issues with skunk2 throttle body and intake manifolds?
hey guys, i am trying to figure out an air leak or something cause im radomly having idle bouncing. i am feeling its the intake manifold and the throttle body i have from skunk2 but i could be wrong.
does anyone have these combo?
do you have random idle bouncing?
i get it after i drive and its warmed up but once in a while at a stop light it will not bounce. the idle is good. then it will do it at a different stop.
only problem i have had with my skunk2 intake manifold is firewall clearance, or lack there of... my iacv is resting against my firewall blanket thing. thankfully i have prothane inserts so my motor doesn't really move at all...
check the vacuum hose to ur pcv valve, jus read a thread called idling issues, he replaced a bunch of sensors and it was his oil catch can(pcv valve) hose
thats already replaced. i am checking hoses. there arent too many hoses. they seem tight and fitted.
what about the temp sensor. since the hole didnt fit perfectly its kinda kinked. i was wondering if i shouldnt have used my old 91 oem sensor.
should i be using a different year or something?
also when i took out the throttle body air adjuster the idle bounced the same as with the round screw was tightly in.
thats strange i have lots of clearance and i got a b16
Joeski99Si
May 22, 2008 06:40 PM
UNDER PRESSURE
Nov 22, 2005 03:30 PM
