car run WITHOUT vtec oil pressure sensor?
Old Feb 19, 2011 | 02:52 PM
frokido's Avatar
Default car run WITHOUT vtec oil pressure sensor?
broke my vtec oil pressure SWITCH and need this car running by the end of the weekend. dont want to start it up and get over 4 grand without knowing im not going to damage anything. any insight?
Old Feb 19, 2011 | 03:09 PM
frokido's Avatar
Default Re: car run WITHOUT vtec oil pressure sensor?
nobody?
Old Feb 19, 2011 | 05:00 PM
frokido's Avatar
noone?
Old Feb 19, 2011 | 05:08 PM
slowcivic2k's Avatar
You need to have that sensor functional for two reasons.
1: So your ECM knows that there is enough oil pressure available to supply the entire VTEC system for proper operation.
2: If such a loss of oil pressure does occur before or after VTEC, you will not further starve the base engine of oil. (IE mains, rods, rocker jets) The engine will switch VTEC off.
Old Feb 19, 2011 | 05:27 PM
frokido's Avatar
this is a permanent shut off of my v tec or will i be able to break it open and turn it back on some how?
Old Feb 19, 2011 | 06:19 PM
Yes, until you replace the switch, VTEC will not work at all.
Old Feb 19, 2011 | 09:00 PM
fungus mungus's Avatar
Mine worked after breaking that switch. You just lose the protection that this switch gives you should your oil pressure drop. I wouldn't advise driving long without it (especially hitting VTEC), but the car will run fine without it until you get a replacement.
fm
Old Feb 19, 2011 | 09:14 PM
The PCM requires that input to turn VTEC on. Either you have bypassed that switch, or your using some sort of aftermarket VTEC control. (IE Chipped ECU or VAFC comes to mind)
Hell VAFC's will turn VTEC on when the car is not moving... LOL
Old Feb 19, 2011 | 10:17 PM
I have a Hondata, so that may be it. I freaked out when I busted the switch and figured VTEC wouldn't engage. But yeah, mine did (I tried it once and backed off). Whether or not VTEC engages or not, the car will run long enough to him to get his replacement switch.
fm
Old Feb 20, 2011 | 05:13 PM
frokido's Avatar
hmmm sounds like some good advice guys i really appreciate it
94wip
12
Jun 20, 2024 07:23 PM
DDream
Sep 20, 2012 05:57 AM
1sikhatch
Jun 5, 2009 07:35 PM
blueeg
Apr 25, 2006 11:16 AM
wannagofaster
Sep 4, 2004 03:25 PM
