Losing coolant but no leaks
My 93 hatch is leaking coolant somewhere and I cannot find any leaks. I had my head gasket replaced, new radiator and new water pump still cant find any leaks. I put about a half gallon in it every two days. And once I shut the car off I play hell trying to start it back up. God someone help me befor I blow it up.....again.
Either end of the water pipe on the backside of the block under the
in. manifold that runs from the thermostat housing to the water pump
is a common source of leaks that is easily overlooked.
But a half gallon every few days is a lot.
So, you did a coolant system pressure test? Kind of confused by this ^
statement.
statement.
I thought about that too, but a half gallon every 2 days is a lot to not notice
for a leak like that, likewise for the water pipe.
I suppose a leaking in. manifold gasket could allow coolant to get sucked
into the engine but I could be wrong.
Yes a coolant system pressure test. And No funny smells from the exhaust. I just dont understand why it will crank and run like a champ first thing in the morning, but after I stop and get gas and turn off the car I cant seem to get it started.
@Dontoh... Yeah that's what I was thinking....that's alot of coolant to be leaving without having dramatic puddles unless it's getting burned off somewhere.
Engine is eating it go get a pressure tester from auto-zone and pressure test it if it leaks then there you go. If it does not then your engine is eating it ! Good luck !
