Trying to fix an oil leak
Old Feb 18, 2011 | 09:45 AM
fortillian's Avatar
Default Trying to fix an oil leak
I have a B18C1 that has started to leak oil. I can see it all around the front of the engine and around/under the distributor and vtec solenoid. Im going to replace the valve cover gasket, distributor o-ring, exhaust cam seal (S2 triple o-ring) and vtec solenoid gasket. As far as the vtec solenoid gasket goes, I dont know which to order. I see one labled upper vtec solenoid gasket and one vtec solenoid gasket with filter. Which one or both? The only distributor oring i found was for a 92-2000 1.5L/1.6L. Will this still work? Any other suggestions are welcome.
Valve Cover Gasket
Vtec Solenoid Gasket with filter
Vtec Solenoid Gasket Upper
Distributor Oring
S2 Cam Seal
Old Feb 18, 2011 | 09:47 AM
mafia's Avatar
Default Re: Trying to fix an oil leak
Get the one with filter. Mine is leaking too Im going to change it soon.
Old Feb 18, 2011 | 09:50 AM
fortillian's Avatar
Does my engine have both? If so Ill replace both.
Old Feb 18, 2011 | 09:52 AM
mafia's Avatar
Yes, it has both.
Old Feb 18, 2011 | 09:55 AM
mafia's Avatar
There you can see both.
Old Feb 18, 2011 | 09:56 AM
fortillian's Avatar
Yes, it has both.
Thanks. If anyone can tell me if that O-ring for the 1.6L distributor will work with my 1.8L distributor then I will be all set. Otherwise Ill keep looking for one specific to my application.
Old Feb 18, 2011 | 09:59 AM
fortillian's Avatar
thanks for the pictures. definately helps out.
Old Feb 18, 2011 | 10:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Man don't go through eBay for all that stuff. You can get all those parts for $45 + shipping from Carland Acura www.acuraautomotiveparts.org Or for $70 + shipping you can get everything plus the 8 washer gaskets for the valve cover bolts (the kit includes the valve cover gasket, plug tube gaskets, and the cover bolt gaskets).
But yes get both VTEC solenoid gaskets. And also order the exhaust cam end plug from a 98+ GS-R. It's plastic, with o-rings, and will never leak like the old style rubber plugs. And it only costs 5 bucks.
But seriously, $5 for that distributor o-ring? It's $1.41 for the correct B18C1 distributor from Carland.
Old Feb 18, 2011 | 10:47 AM
fortillian's Avatar
Originally Posted by PatrickGSR94
Man don't go through eBay for all that stuff. You can get all those parts for $45 + shipping from Carland Acura www.acuraautomotiveparts.org Or for $70 + shipping you can get everything plug the 8 washer gaskets for the valve cover bolts.
Thanks for the heads up, and the tip on the 98+ cam seal.
Old Feb 18, 2011 | 11:07 AM
Community Builder
I replaced my leaky rubber plug with the revised plastic one 8 years ago. I replaced it again last year doing the same thing you're doing (chasing an oil leak) but I know that wasn't the part that was leaking. So I could still be using the plug I installed in 2003 and I'm 99.9% sure it still would not be leaking today. That's pretty good for a $5 part.
I also apply a thin layer of Hondabond (Permatex Ultra Gray sealant) around it before installing.
airikkCRX
Jan 25, 2024 03:11 PM
ridin
Apr 2, 2016 09:43 PM
ElectronBlue00
12
May 15, 2013 08:59 AM
ttmix
Jul 30, 2012 06:53 PM
95autocivic
Jan 9, 2006 06:00 PM
