clutch bleeder valve
Old Feb 17, 2011 | 11:31 AM
sssettlejr's Avatar
Default clutch bleeder valve
How the hell do you reach the clutch bleeder valve? It is behind the engine mount and below the radiator hose and the hydraulic line is right next to it. It seems impossible to get to!
Old Feb 17, 2011 | 12:06 PM
Targa250R's Avatar
be professional
Default Re: clutch bleeder valve
Huh? It's right out in the open; it couldn't possibly be more easy to access.
What year is the car? What are you having a problem with?
Old Feb 17, 2011 | 12:13 PM
sssettlejr's Avatar
the year might help... its a 2000 accord and I just found my haynes and they say you have to go from the bottom of the car to get to it so I think I was looking at the wrong thing... it looks so much like a bleed valve though
Old Feb 18, 2011 | 09:50 PM
nus_dogg's Avatar
The slave cyl is located in front of the transaxle.
Old Mar 19, 2017 | 03:51 PM
Hondra's Avatar
Signed up to ressurect this old thread. I'm having the same issue as the OP with the same year Accord. The bleeder screw between the front engine mount and the fluid line. I can get the closed end of the 8mm wrench on to the bleeder but can't get a good turn on it anyway.
​​​​​​Thanks for reading
Kimberly Owens
Nov 9, 2017 02:52 PM
skbut
May 27, 2009 03:15 PM
gtowni3
Feb 27, 2005 11:57 AM
hakemjmba
Jun 24, 2003 09:36 AM
BrandonClaps
Apr 20, 2003 04:43 PM
