Shifting WITHOUT releasing the throttle
Old Sep 25, 2002 | 02:51 PM
shamoo's Avatar
Will you make something up for me please?
Default Shifting WITHOUT releasing the throttle
Is this a good thing to do? I usually let go of the throttle when I'm by myself, but at times with a passenger, just to maintain a smooth shift, I'll keep the throttle open shift, and release the clutch.
The bike will shift very smoothly without any jerking at all.
Should I do this? Or stop immediately?
Old Sep 25, 2002 | 02:56 PM
falcongsr's Avatar
What is this crap?
Default Re: Shifting WITHOUT releasing the throttle (shamoo)
this sounds like power shifting where the rpms shoot up between shifts and the clutch has to slip like a **** as the flywheel slows down to the new gearing. its going to shorten the life of the clutch obviously.
Old Sep 25, 2002 | 03:39 PM
shamoo's Avatar
Default Re: Shifting WITHOUT releasing the throttle (falconGSR)
It sounds like it, however I don't rev up the throttle at all, I just keep it at the same point. I shift quick and the rpm's don't increase at all. Even if I shift slowly, the rpm's doing go up.
Old Sep 25, 2002 | 04:57 PM
NotRiTe20's Avatar
Shift fast using the clutch. Thats why the clutch is there so use it. You will always have smoother shifts if you do it fast. Thats the way the bike was built to be shifted. FAST !!!
Old Sep 25, 2002 | 05:34 PM
shamoo's Avatar
Default Re: Shifting WITHOUT releasing the throttle (NotRiTe20)
I was asking about the throttle though, obviously you use the clutch.
Old Sep 25, 2002 | 06:41 PM
tonydatyga's Avatar
Actually sometimes when going up aggresively I go ahead and preload a little clutch and upshift "clutchless". After teardown of about 6k miles on an oem clutch generall rated good for about 15k I didn't see any evidence of uneven or over spec wear. Keep in mind this isn't straight shifting w/o touching the clutch lever. As for keeping the throttle cracked, its fine. It will put a little more load on the clutch being that w/o dropping rpm during upshifts it has a larger difference between engine and gear speed to compensate for. As long as you're smooth I don't see anything terrible w/ that either. You'll know when its not smooth or its a little too much to ask frmo the clutch. You can feel it struggling a little before it reaches the slipping point. Actually, thinking about it now I think I may leave it cracked when I'm riding aggresively. Course I always ***** it w/ a ***** on the back.
Old Sep 26, 2002 | 08:38 AM
shamoo's Avatar
Default Re: Shifting WITHOUT releasing the throttle (tonydatyga)
Nicely put!
Thanks for the info though.
Old Sep 30, 2002 | 07:07 AM
Luke's Avatar
So, you are using the clutch but holding the throttle wide open? That will hurt your cultch as you are slipping it under max rpm and under high load!
Learn to change by dipping the throttle, or better still learn to match the power and use the clutch. Can't think why you would do this with a pillion?
Old Sep 30, 2002 | 08:49 AM
falcongsr's Avatar
What is this crap?
Default Re: Shifting WITHOUT releasing the throttle (luke)
i dont think he's holding the throttle wide open. anyhow the clutch is probly seeing more abuse from other circumstances than when he's riding 2 up and trying to be Rico Suave
Old Sep 30, 2002 | 10:02 AM
shamoo's Avatar
Yeah, I'm not holding it wide open. Let's say I'm in 2nd gear accelerating lightly. The throttle is twisted a certain amount. When I shift into 3rd, I don't move the throttle at all, I hit the clutch real quick and shift, and that's it. The rpm's stay constant and then I can accelerate some more until the next gear.
Am I explaining this okay? Is this okay to do? I don't feel any strain on the clutch at all.
Old Sep 30, 2002 | 03:13 PM
tonydatyga's Avatar
Either way you'll know in a couple months
Old Oct 1, 2002 | 06:41 PM
Greg900rr's Avatar
a smooth shift is a good shift. you are not hurting anything.
NAH2B
Sep 7, 2015 11:11 AM
milkstatus
Jul 14, 2007 12:42 PM
Accord2k-Hybrid
Jul 16, 2006 06:46 PM
precisionelite
Jun 7, 2006 12:17 PM
civicheaven151
Jul 7, 2002 07:04 PM
