What is double clutching
Re: What is double clutching (Chad)
Something that mostly racers with synchro-less transmissions do. When you downshift,you push in the clutch, put the car in neutral and blip the throttle so that the rpms on the input shaft match the speed of the output shaft. Then you puch the clutch back in and shift into the lower gear.
i'll take this one. double clutching is what it sounds like. depressing the clutch twice. i know i use it to do 3-2 downshifts. even though i heel-toe, it will grind. so i double clutch it and it goes in no problem.
example using 3-2 shift.
brake
push in clutch and shift to neutral
release clutch and rev using the side of my foot while still braking
push clutch in, shift to 2nd and release clutch.
sometimes i will blurp the throttle twice. once when i go to neutral and once before i release the clutch in 2nd.
hope that helped.
-spencer
brake
hope that helped.
-spencer
Re: What is double clutching (civicheaven151)
Just to clarify... because the two often get mixed up and intertwined...
The throttle "blip" or rev-matching is not really a part of the double-clutch. Sure, it's the way you're supposed to do it, but if you're going to start labeling things, techincally, I'd call that a separate "skill".
But yea,
depress the clutch,
put the car into neutral,
release the clutch,
depress the clutch,
put the car into gear,
release the clutch.
But yea,
depress the clutch,
release the clutch,
depress the clutch,
release the clutch.
Re: What is double clutching (743teg)
ThaEfSwap
11-29-2011 06:37 PM
