eg hatch, jdm b16a cold start, high rev??
Hey guys im new here. but i just had a quick question. My 95 civic with the JDM b16a swap revs at about 3k rms when i first start it. I just got a Skunk2 Intake manifold so when i take the oem one off. im gona clean the IACV and FITV. Any Ideas??? Thanks
Without IACV operation, idle should be 450-500rpm with PCV air only, if its higher than this, you have a vacuum leak, or the throttle is cocked open.
Adjust the idle screw only AFTER you have ensured there are no air leaks in the manifold to 450-500rpm HOT.
peterJDM
Jul 6, 2012 10:45 AM
