car goes straight to limiter
okay so ive searched this everywhere and its killing me lol nothing at all. but its winter and cold here for a while, so i started my car up on a pretty warm day well it was 0c out and i pressed the gas a bit and it went straight to limiter and bounced off so i turned it off, i tried to start it up again and it started find but went straight to the limiter again and bounced off??im really clueless so any helps very appreciated
okay so i checked it out and its loose at my gas pedal, like i can tug on it and get slack. does this mean its broken and if so would that cause it to start up and go to high rpms right away?
Loose at the gas pedal is usually an indication that it will be tight at the throttle body. Open your hood and check to see if the throttle body is stuck wide open. $10 says it is!
You probably need to clean and lubricate the throttle body &/or the throttle cable.
Now if you adjusted the cable tighter it probably wont close now.
Can you post up some pictures of the throttle body cable and real?
Make sure that you adjust the throttle cable again after you get the throttle body cleaned up and installed. It's could be a wee bit on the tight side as it sits now.
integrainside
Jan 25, 2010 07:07 PM
