d16y7 head on d16z6 block
ive read a lot about this but unsure what timing belt to use or headstuds im always reading 2 different stories.im planning to go boost i have all my parts and a z6 block sitting.i rather use that due to y7 oil pump.and im doing y7 head since i want to keep my port and regrind cam.i just need to know what studs timing belt pully all that good stuff.p.s this is going to be vitara block with y7 head.
thanks honda tech
thanks honda tech
For the headstuds, use d16y7 pieces. The threads in the block are most likely identical, I know with a d16y8 and a d16z6 the bolt closest to the distributor is a different length but the threads in the block are the same, it's a difference in the head.
Honda Part Numbers:
D16y7 Timing Belt 14400-P2F-A01
D16z6 Timing Belt 14400-P28-004
D16y7 Head Gasket 12251-P2J-004
D16z6 Head Gasket 12251-P08-004
Advance Auto Pieces:
FelPro D16y7 Head Gasket 9915PT
FelPro D16z6 Head Gasket 9915PT
BeckArnley D16y7 Timing Belt 026-0307
BeckArnley D16z6 Timing Belt 026-0307
Honda Part Numbers:
thanks man u helped a lot! just finished my vitara block now needa order up some headstuds ana start breaking it innn.so z6 and y7 timing belts the same?
I haven't timed it yet or even torqued it down because it's not TDC yet. Just wanna know if I can drive it with only one bolt in. And will it stay timed? Don't want the distributor blowing up or popping out
Jayboy
Apr 23, 2005 03:43 PM
94maroonturbocp
Apr 27, 2004 06:19 PM
JSPECHB
May 11, 2003 07:29 PM
