93 gsr master cylinder
Old Feb 15, 2011 | 11:29 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default 93 gsr master cylinder
i just add new dot3 brake fluid.i have'nt drive it in couple week.after that i notice there was a leak from the mc.do i need a new mc or just replace da seal on da old one??help asap.
Old Feb 16, 2011 | 06:29 AM
Gekko's Avatar
Default Re: 93 gsr master cylinder
I would ask this question in the "Brake" section. Where is the master cylinder leaking from? The brake lines? At the reservoir?
Old Feb 16, 2011 | 10:30 AM
Genetically Gay
i think is leaking from the resevoir.
Old Feb 16, 2011 | 11:42 AM
Scooooter7's Avatar
Did you "overfill" it? Or has the level gone down again?
Old Feb 16, 2011 | 11:47 AM
Genetically Gay
no..i did'nt over fill.i can see it on da ground.and i can see it ate some of the paint from where it leaks.
Old Feb 16, 2011 | 12:28 PM
Gekko's Avatar
If it is leaking from the reservoir where it meets the cylinder you can just tighten it. If it is leaking from the cap then you either overfilled it or the fluid is somehow spilling out when you drive. Clean up the outside of the reservoir and cylinder and then check where it is leaking from.
mattmw88
Mar 31, 2008 06:08 PM
93sivtec
Dec 23, 2007 08:17 AM
integra123
Aug 8, 2006 05:52 PM
erniecars
Nov 18, 2002 12:41 PM
