Honda S2000 Honda S2000
S2K Wheel help
Old Feb 15, 2011 | 07:53 PM
corince06's Avatar
Default S2K Wheel help
Hey guys I have an 03 and have been looking around for some new wheels for awhile now but am having trouble finding ones that have the stock offset. Kinda new at this stuff still and was hoping for some help. I was looking at the SSR Type-C and was wondering if you guys could tell me what size and offset would be best for me. Thanks
Old Feb 15, 2011 | 08:00 PM
corince06's Avatar
Default Re: S2K Wheel help
Here is the link for the wheels. http://www.ssr-wheels.com/wheels/typec_171819.asp
Old Feb 15, 2011 | 08:04 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
This is pretty impossible to answer man. You should look through the picture threads and find the "look" you want. Ask more specific questions about what you need to do to achieve that look.
Or figure out what purpose you have for the car. Diameter of wheels, lowering mods, useage of the car, fender mods that you'd be willing to do, etc. are all details that anybody would need to know to help you.
Generally, the aftermarket widths used on S2000s without lots of fender mods are 17X7.5-17X8 up front and 17X9 to 17X10 out back. Fitments have a lot to do with offsets and tire widths, and how much you want to lower the car.
Old Feb 15, 2011 | 08:25 PM
corince06's Avatar
I want to lower my car an inch in the front and rear with tein flex coilovers. I am building it to run time attack's at the local track. I would like to use 17x7.5 in the front and 17x9 in the rear. I just dont know what offsets are going to be able to work or not. As far as fender mods i would rather not do any if possible.
Old Feb 15, 2011 | 11:21 PM
vain's Avatar
if you lower your car, i highly advise rolling your fenders (especially if you're going to be doing hard cornering).
anyways, the mildest setup you're going to get with those widths are 17x7.5+49 and 17x9+41 ... while the front will probably be fine, but the rear will probably rub. though, i see a 17x9.5+65 --- that's a more conservative fit, but it might still rub. let me crunch numbers when i get in the office tomorrow
Old Feb 16, 2011 | 12:32 AM
corince06's Avatar
I was just wondering if the 17x7.5+49 front and 17x9+41 rear will work with a fender roll or not. If not I guess I will just have to find some new ones lol. Thanks man
Old Feb 16, 2011 | 04:27 AM
camoy's Avatar
Front may work with chamber depending on how the tire sits. The rears will not work without a roll and some chamber, esp since you are problably going to run a 255 or greater tire in the rear since the 9in rear is wider than stock.
Old Feb 16, 2011 | 08:30 AM
vain's Avatar
for the 17x9+41 rear, you'll at the least need to relocate your bumper tabs... i'm sure that part will rub under load. it actually looks like the 17x9.5+65 would fit better since you'd be more conservative by 18mm.
Old Feb 16, 2011 | 09:44 AM
ExVtec's Avatar
At first glance I thought it said wheel "hop" lol.
*hits backs button*
Old Feb 16, 2011 | 11:38 AM
Booztin's Avatar
To help you out I ran 18x8.5 +51 with a 225/40 tire upfront on factory camber and i was tucking , needed a slight fender roll and fender liner trimmed a tiny bit. My rear was 18x9.5 +49 with a 255/35 tire on -2.5 camber my rear was also tucking needed a fender roll and relocated the bumper. My front coils were 2-3 clicks from stiffest setting and my rear was 4 clicks from softest. I drive pretty hard when I do. The ride felt great and never ever ever rubbed.
The rear was as flush as I would suggest unless you wanna run more camber but the front coulda fit a +45 to a + 50 i was just being safe.
Old Feb 16, 2011 | 06:47 PM
corince06's Avatar
Thanks for the help everyone
Old Feb 16, 2011 | 07:17 PM
bigmacnfries's Avatar
pics of the end result or ban
Old Feb 16, 2011 | 08:05 PM
vain's Avatar
yes plz. i'm curious to see what you do.
Old Feb 17, 2011 | 09:12 PM
corince06's Avatar
Will do. Its gonna be a few months though I'm just trying to figure out which ones I'm going to get right now
Old Feb 17, 2011 | 11:02 PM
corince06's Avatar
actually i just found these and was wondering if they would fit with no rubbing issues or not?
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Feb 17, 2011 | 11:28 PM
vain's Avatar
17x7.5+48, 17x8.5+59 .. that's a very mild/conservative setup (at least, in my opinion). if it were me, i'd probably go with the type-c's... but then again, i'm biased towards ssr's
edit - i take that back. while that's mild to me, it'll probably still rub in the rear unless you relocate the bumper tab.
don't fear rolling the fenders... it's better than flipping your tab. trust me. i've been there
Old Feb 17, 2011 | 11:31 PM
corince06's Avatar
I would rather have the SSR's too. But I also would rather not have to do a fender roll.
Old Feb 17, 2011 | 11:36 PM
corince06's Avatar
Ok well how do I relocate the bumper tab??? Never heard of doing that before lol and i'm not afraid to roll the fenders just dont have anyplace where i live that i would trust doing it.
Old Feb 18, 2011 | 12:08 AM
HdeucedeuceA's Avatar
I have 17x9 +63 TSW Nurburgring's wrapped in 255/40 star specs sitting in my room waiting to go on. No modding required; hopefully.
Old Feb 18, 2011 | 08:49 AM
vain's Avatar
ahhh. if you were in the bay, i'd help you do it
anyways, this is for the rear bumper - http://www.s2ki.com/forums/index.php...#entry14909750
basically, where the rear bumper meets the quarter panel, there's that "shelf" like piece which has a screw holding them together. i dremel'd the "shelf" piece as far back as i could go while leaving room for me to drill a hole into both pieces - then i ziptied it. i'll try and get pics sometime when i can jack my car up again.
as far as rolling the front - make sure they've done s2000's before. there's 2 tabs on each side that needs to be cut/dremel'd before you can roll (if you don't cut it, the roll will be lumpy).
Old Feb 18, 2011 | 06:51 PM
corince06's Avatar
Yeah i'm on the other side of the country man lol. That link showed me how to do it pretty good. i think i got it. and yeah i've only seen like two other s2k's in my area so odds are no shop has ever done a fender roll on one. thanks for the help man
Old Feb 18, 2011 | 07:55 PM
MV99-S's Avatar
17x8+45 and 17x9+35 RPF1's with conti extreme DW tires 215 and 245 will fit on a 1 inch drop within standard camber specs
The reason I mention the RP's btw is that SSR's are garbage the SSF process lead them to reduce the amount of material and still pass basic crush tests and as a result the lips are fragile and for time attack your going to have to run ***** out over the curbing ect.
BTW tin is garbage
read through this and the related articles before you spend a dime
http://www.modified.com/features/scc...out/index.html
Old Feb 18, 2011 | 10:48 PM
Brenten's Avatar
Hi,
You would also have to bend the fonders to replace tires with these.
Other wise could cause rubbing problem after fitting it to your car.
Thanks
Old Feb 19, 2011 | 02:53 AM
Boots's Avatar
Originally Posted by Brenten
Hi,
Thanks
stop posting on this site
Jdmkdmkid
May 2, 2013 05:28 PM
C_Rock77
Apr 26, 2009 01:31 AM
powerdbygarrett
Jul 13, 2007 08:54 PM
SonicK20Z
Apr 4, 2006 04:02 PM
poo flinger
38
Nov 13, 2002 09:44 PM
