Fuel System help, need some advice on my options.
Old Feb 15, 2011 | 02:53 AM
Topdawgg's Avatar
Default Fuel System help, need some advice on my options.
Currently I have a dual walbro setup in my car. I also have a set of RC1000's.
I am currently looking to upgrade my injectors to give myself some more room to go bigger.
I was looking in to ID1000's but I was informed that the dual walbros will not like the higher pressure that the ID's will require.
I was thinking about going with 2000's but I can't run C16 with them appearently.
Should I change my fuel pumps and go with something different so I can run the ID1000's? Or should I look at the 2000's and run a different type of fuel.
The power goals for the car are around the 650whp+ range. With room to go bigger down the road.
Old Feb 15, 2011 | 03:03 AM
gogetta's Avatar
Default Re: Fuel System help, need some advice on my options.
You can run C16!
You cant run Q!
Old Feb 15, 2011 | 03:11 AM
Topdawgg's Avatar
perfect, C16 is readily available around here.
Old Feb 15, 2011 | 05:28 AM
habib's Avatar
Here is a chart Tony came up with to show pump and injector combos
[/QUOTE]
Old Feb 15, 2011 | 06:34 AM
paulzy's Avatar
you'll be fine with the 2150's/IJ2000 with the current pump setup and your goals.
Old Feb 15, 2011 | 12:40 PM
Topdawgg's Avatar
that chart helps, but it doesnt really give me a good idea with the dual Walbros
Old Feb 15, 2011 | 12:53 PM
Turbo-charged's Avatar
im not a fan of the dual walboro set up as ive seen so many single walboro's fail...but we have done a few cars in the 800+hp range that are on dual 255's and old school 1600's. now that ID has a 1600, thats an option and they are a little cheaper than the 2000's. with the dual 255's i would go with a bigger injector than a 1k.
Old Feb 15, 2011 | 01:42 PM
Topdawgg's Avatar
thanks for shedding some info in this thread, you have been great help so far through pm's
Old Feb 15, 2011 | 01:59 PM
Deatschwerks's Avatar
If you already have dual Walbro setup, our DW301 should be a drop-in replacement and that would give you some headroom above the Walbros.
...and just to add a couple of injector options, we have our B/D/H series injectors in 1000cc and 1300cc sizes. You should be able to run a 1300cc injector @ 43.5 psi base pressure and enough fuel for your power goals. ...and on gasoline fuels, our DW301 should be able to handle that power range with just one pump.
We have a fuel calculator on our website, should help give some help with sizing, too: http://www.deatschwerks.com/fuel-calculators/
Old Feb 15, 2011 | 05:18 PM
portenio78's Avatar
Just get the id2000's bro. You'll be set from there. You have the volume and wont need to run super high fuel pressure out of them to reach your goal.
Silvertc
Jan 10, 2010 09:05 PM
Boostage
Jul 3, 2009 03:21 PM
TurboGSR96
Nov 22, 2008 10:45 AM
Da K00l Aid Mayun
Sep 21, 2005 11:24 AM
Blaze45
Oct 2, 2004 04:52 AM
