Front Tire Rubs..Dirver side only??
Old Feb 14, 2011 | 03:51 PM
javadsmm's Avatar
Default Front Tire Rubs..Dirver side only??
SO I installed a set of Ksport coilovers yesterday on my 93 Del Sol. Its a pretty aggressive drop but I am only getting some serious rubbing issued from the drivers front. I noticed that there is a gash about 2mm deep down the center of the tire and a little bit on the lip of the tire too.The thing is, it is about .75cm higher than the passengers side.
Any ideas why its worse on the drivers side? or what I can do to resolve this? besides raising it more? i.e. roll the fender or remove fender lining?
Old Feb 14, 2011 | 03:59 PM
EJ8_Man's Avatar
Default Re: Front Tire Rubs..Dirver side only??
Chances are your car was hit there at one point in time and then bondoed over, you'd be able to tell if that was the case. You can roll the fender, and remove the lining, that will help.
Old Feb 14, 2011 | 04:05 PM
virgineg6's Avatar
passenger side spring not seated correctly?
EJ8_Man's Avatar
^--- Good idea
Old Feb 14, 2011 | 06:07 PM
wannaBjdmca6's Avatar
Originally Posted by EJ8_Man
^--- Good idea
NO, the whole "seating" its bs. the springs or whatever dont "settle" your bushings are probably **** or your car was in an accident and somethings bent
Old Feb 14, 2011 | 06:45 PM
EJ8_Man's Avatar
I remember there being a groove that the spring fit into. I wasn't thinking the spring settled, I was thinking maybe it was off center. Then again if it was off center it would probably make some nice noises over bumps... But yeah my initial thought was the car was in an accident of some sort
Old Feb 14, 2011 | 07:00 PM
virgineg6's Avatar
i said seated not settled 2 totally different things! as in not sitting as it should.
are they both set at the same height?
Old Feb 14, 2011 | 07:05 PM
TwoFaced's Avatar
I'm gonna say prior accident. Have an alignment place put it on a rack and take some measurements.
Old Feb 14, 2011 | 07:30 PM
psudo-si's Avatar
i had the same experience with my old coupe, it had been in a rear accident and my right coilover had to be set three threads lower then my left coilover for it to sit level.
Old Feb 19, 2011 | 09:37 PM
javadsmm's Avatar
Bingo!
I compromised and raised it about half an inch do clear the damaged wheel well. Thanks for the input.
Old Feb 19, 2011 | 10:15 PM
TwoFaced's Avatar
Cool...I would really have it checked out. I thought I bent my subframe because my wheel was sitting back in the well a bit and would scrape the inner well over bigger bumps...put it up on the lift and my front lower control arm was **********ed up. It can be really unsafe, and will cause all kinds of bad tire wear. Best of luck with a total fix on it glad you got it working for now.
Jdmkdmkid
Jun 2, 2013 10:12 AM
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
zach1288
39
Aug 3, 2007 08:22 PM
clemsonteg
Suspension & Brakes
Sep 5, 2006 02:35 PM
tylerdurden
11
Dec 7, 2002 12:28 PM
