HX O2 sensor Help!!
i got a 96 hx and it s throwing engine code 65. i've replaced the 5wire o2 sensor twice cleared the code. within 2 miles of driving engine light come on for the same code.
is there anything i'm doing wrong?
does somebody have a picture of the oxygen sensor diagram in their hx?
Wow, $400 O2 sensor egh? Are we talking about the same sensor? I just replaced my primary on my civic last weekend... it was $80 new.
I would check your secondary O2 sensor wiring harness. Maybe a wire got severed somewhere between the cat and engine bay. At least on mine, the wiring has a bung that fits into the frame. Maybe yours came loose and got cut on the frame.
i believe the 5 wire o2 sensors are specific for hx and vx models only. the cat is mounted on the exhaust manifold and both o2 plugs sit rite under the top radiator hose. i've checked the wires at that point and seemed to be ok. i cant think of anything else to do but to take it to the shop
65 is old school Honda codes, 6 long flashes, 5 short.
141 is OBD2 and the equivalent code. P0141 if it makes you feel better.
That'is all you will get, another form of the same code. It is still up to you to find what is causing it.
gotcha, i was thrown off by the missing p0. looks like its time to start troubleshooting the wiring then
924drb20
Dec 14, 2010 10:36 AM
allmotorEG-SI
12
Jul 25, 2004 12:43 PM
