Direct Vtec Wiring
Old Feb 12, 2011 | 09:29 PM
sameerb1's Avatar
Default Direct Vtec Wiring
I swapped my prelude from F22 to Vtec H22 using the F22 Harness. I bought a Neptune RTP chipped P06 ECU (still trying to figure out how to run that with sane idle) and am trying to get my vtec running.
After reading a whole bunch of vtec connection articles, i have following things to tell you all.
My vtec does not have an oil pressure sensor, its JDM that's normal
I dont have the Knock sensor or the AIB wired anywhere, their wires are just cut so i think i dont need them, can turn them off with Neptune
basically my question is, i am connecting my vtec wiring, can i directly go from vtec solenoid to the ecu without going thru the wire thingy on the tower
Wire thingy
or this wire thingy
Waiting for your answers as my vtec is wired and waiting for getting in the ecu A4 pin
Old Feb 14, 2011 | 11:43 PM
sameerb1's Avatar
Default Re: Direct Vtec Wiring
not a single reply!?
Old Feb 15, 2011 | 03:58 AM
SLIM NOTHING's Avatar
yes you can.. thats how my b18c1 is. although i needed mine to go to the pressure switch also.
Old Feb 18, 2011 | 09:08 PM
sameerb1's Avatar
^ thank you very much, that all was required in my car, i dont need the pressure switch by the way.
Old Feb 22, 2011 | 08:33 PM
ktsciv93's Avatar
yes you'll b fine with wiring it straight to the solenoid
tankizk
Jul 24, 2007 10:36 PM
Macleod95Civic
Nov 3, 2004 08:54 AM
AngelTeg
Aug 24, 2003 07:03 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
