wiring vtec
Old Feb 12, 2011 | 10:57 AM
92lxsleeper's Avatar
Default wiring vtec
does anyone have a diagram of where on the engine haness i would add the 3 pins for vtec?
i have a 92 hatch so its already wired for vtec at the ecu, and i have a spare dx harness laying around that i can salvage plugs off of, so id rather add the wires to my existing dx harness than to buy an ex harness.
thanks
Old Feb 12, 2011 | 11:21 AM
EFPhilly's Avatar
Default Re: wiring vtec
You might have to hard wire. de pin the two vtec pins at ecu...apply power via 9-volt battery and a ghetto ground somewhere and pull the harness apart at the other end and look for voltage with a multimeter. Mark spot and trace wires to where they go...This should be the same with both harnesses...but not looking at my book so not sure.
Back of the Haynes has detailed wiring diagrams for days
Old Feb 12, 2011 | 11:48 AM
94EG8's Avatar
Seagull Management
Here you go:
Black ground wire from the pressure switch can grounded where ever (In an EX/Si harness it gets grounded to thermostat housing
EFPhilly's Avatar
^ psssh too easy
the hard way is much more fun
Old Feb 12, 2011 | 12:32 PM
thanks
Old Feb 12, 2011 | 03:26 PM
CivicxTree754's Avatar
Photogenic
Loved
Good info. Im doing the mini me swap so this will only take minutes.
Old Feb 12, 2011 | 05:17 PM
JDM-sol 89's Avatar
Why can't every question be answered this way with such amazing pictures??
Old Feb 12, 2011 | 05:45 PM
EFPhilly's Avatar
That picture hails from the FAQs, if I'm not mistaken. So it has been answered and stickied prior.
But I agree...!
...but people should also read the FAQs. So much good info in there...
Old Feb 12, 2011 | 06:12 PM
94EG8's Avatar
Seagull Management
But I agree...!
I think it's in the FAQs, I pulled it, along with most of the other pics like it that I use off ff-squad.
Old Feb 12, 2011 | 11:15 PM
EFPhilly's Avatar
Very nice job FAQs section is top notch and answers so many questions. Thought I had seen it on there....my memory serves me right
slow_cx
Aug 22, 2007 11:11 AM
Mr. Roboto
Oct 27, 2006 05:03 PM
Br1anPham
Oct 11, 2004 11:15 AM
blkDOHCsol
19
Oct 9, 2002 05:23 AM
