Need some help figuring out where my oil leak is coming from
Old Feb 12, 2011 | 09:59 AM
auspilot's Avatar
Default Need some help figuring out where my oil leak is coming from
I'm trying to track the source of an oil leak. This is actually on a 98 Odyssey, but it's an F23A engine and I think this site is more active than the Ody forum.
The oil is coming down the back of the block mostly on the driver's side. It's not the oil cooler o-ring or the oil pressure switch. The highest point I can see it is on a little "shelf" of metal that sticks out at the top of the block on the driver's side - there's actually a puddle of oil in a depression on this shelf. The first pic is a low mag showing the general location, and the 2nd shows the oil on this shelf thing. Anyone seen this before? TIA
Old Feb 12, 2011 | 10:27 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Need some help figuring out where my oil leak is coming from
Are you sure the cam/valve cover is not leaking on the backside? Are you loosing any oil between oil changes? Looking at the oil fill cap and how damp the cover is there, I would also wonder if its just simply from oil being spilled during an oil change, and it just puddles there.
Old Feb 12, 2011 | 11:37 AM
auspilot's Avatar
No it's not from spills. I can clean it with Gunk between fills (which I do myself) and it shows up again soon. It's not a huge leak. It just started recently but I'd guess it's a quart/1000mi -- but the drips are adding up to a puddle on the garage floor! It could be the valve cover gasket but I don't really see it coming down from there...
Old Feb 13, 2011 | 04:51 AM
poorman212's Avatar
If you are going to pull the valve cover-replace the gasket. While you have it off, pull the upper cover for the t-belt and check around the cam seal....how close are you to neeing to replace the t-belt?
Old Feb 13, 2011 | 05:42 AM
Dannyvho's Avatar
Yes this is probably caused by a leaking valve cover gasket. I had this problem on a F18B2 at 100K (9 years old): not a real leak yet but the gasket looked 'sweaty'.
Old Feb 13, 2011 | 06:01 AM
phootbag's Avatar
Leaking valve cover gasket or front cam seal. Or, your buddy is sneaking in there at night just to mess with you.
Old Feb 13, 2011 | 06:04 AM
andyz's Avatar
Clean the whole area with carb cleaner thoroughly and then cover the area/suspect gaskets points with baby powder to see exactly where it's coming from.
Old Feb 13, 2011 | 10:11 AM
phootbag's Avatar
Ultra Violet dye, if you have it, is the best thing when trying to diagnose oil leaks. No need to clean anything off at all.
Old Feb 13, 2011 | 02:13 PM
auspilot's Avatar
Okay, thanks everyone. Looking at it again I see how it could be the valve cover gasket or the cam seal. It will have to wait until next weekend before I get at chance to take the cover off and look. Both were supposedly replaced 3yrs/35k ago when I had the timing belt changed, so I'm suprised there's a leak already...
Old Feb 13, 2011 | 02:29 PM
TheMuffinMan's Avatar
He knows where you live!
I would second the valve cover gasket or cam seal. If you use High Mileage oil it causes the seals/gaskets to swell up to prevent leaks, however this can also be detrimental and cause leaks as well. Just tossing it out there as a possibility. It's also possible they replaced and never removed a piece or two of the original, causing a gap for oil to seep from - this seems to happen moreso on the oil filter, but definitely could occur on valve cover too.
Old Feb 13, 2011 | 04:32 PM
phootbag's Avatar
Could be as simple as the guy who did the job didn't put any sealant in the crotch of the cam cap. I've seen that a million times.
Old Feb 13, 2011 | 09:31 PM
holmesnmanny's Avatar
I've never seen a leak in that spot, I bet phootbag is right
EGgoJDM
Dec 1, 2009 12:05 PM
Serenity Now!
Jan 29, 2007 06:31 AM
yojimboRSX
Jul 12, 2005 12:59 PM
mixxed
Jun 27, 2003 07:52 AM
