ZC swap help?
Old Feb 11, 2011 | 11:58 AM
bubbashane's Avatar
Default ZC swap help?
i need help with my twin cam zc swap into a 2000 civic it cam out of a 95 civic i need help with wiring harness do they make converters or does any one know someone who mite have a harness
Old Feb 12, 2011 | 12:59 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: ZC swap help?
if i remember right, the dohc zc can use d series manifolds. if this is true, swap over y8 im, etc and make the motor obd-2 or use a jumper harness.
Old Feb 12, 2011 | 05:37 AM
94EG8's Avatar
Seagull Management
Nope, bolt pattern for the intake manifold is different. Bolt pattern for the exhaust is the same but the ports are shifted slightly to one side so if you use anything but a ZC exhaust manifold you should port match it. I sincerely hope that's an OBD1 ZC. You can make them work reasonably easy. OBD0 Models will require an OBD1 distributor which are notoriously difficult to find.
Old Feb 13, 2011 | 05:33 PM
bubbashane's Avatar
this still does not help my wiring problems
Old Feb 13, 2011 | 06:20 PM
92lxsleeper's Avatar
yes all you need is the obd2b to obd1 harness for the computer, and run your p09 computer.
Old Feb 13, 2011 | 07:16 PM
fonkernuckle's Avatar
You can also run the ecu that is for that engine, obd-1 zc= p29
Old Feb 14, 2011 | 10:20 AM
bubbashane's Avatar
what harness should i use cuz the one that was for my motor wont work for that jumper harness stuff
(z6ef)187
May 31, 2011 05:49 PM
EJ1_samson
Nov 14, 2009 08:33 AM
Gold DA9
Dec 20, 2006 03:41 PM
The Destroyer
11
Dec 30, 2005 02:22 PM
clutch878
Apr 21, 2005 03:07 PM
