92 vx b18c1: temp. reads low!!!
Old Feb 11, 2011 | 03:45 PM
rhymeshark916's Avatar
Default 92 vx b18c1: temp. reads low!!!
Rebuilt motor with less than 100 miles and my temp. gauge is reading super low. Replaced a new oem t-stat. Barely reading over above C line. When I put the heater on full blast, it drops all the way down. Also it never peaks around middle needle. Although the fan do turn on. Upper and lower radiator is normal hot. What could be the culprit? Please help me.
Old Feb 11, 2011 | 03:58 PM
Default Re: 92 vx b18c1: temp. reads low!!!
ttt
Old Feb 11, 2011 | 04:00 PM
virgineg6's Avatar
I dont have any actual troubleshooting steps, but i would check the wires for continuity, try swapping out the temp sensor (located underneath distributor only has 1 wire running to it) and if that didnt fix it then swap out the cluster.
Old Feb 11, 2011 | 04:04 PM
Are you talking about the single wire with a black rubber?
Old Feb 11, 2011 | 04:06 PM
virgineg6's Avatar
yeah that sounds right
Old Feb 11, 2011 | 04:08 PM
The only thing is I don't have a multimeter reader.
Old Feb 11, 2011 | 04:15 PM
virgineg6's Avatar
yeah your gonna need 1, there is other ways but there hella ghetto! lol!
Old Feb 11, 2011 | 04:16 PM
virgineg6's Avatar
actually, try bleeding the system properly first!
Old Feb 11, 2011 | 04:21 PM
I did. Let the fan turned on twice. The engine is really hot but not what the temp. gauge says.
Root16
10
Jan 13, 2013 03:50 PM
klinster
Sep 23, 2009 04:19 PM
zippakilla
Feb 21, 2009 11:02 AM
xdustin513x
Oct 14, 2008 12:01 PM
civicguy167
12
Dec 3, 2005 05:46 AM
