Cold start idle problem JDM b16b
Old Feb 11, 2011 | 06:44 AM
inovative91's Avatar
Icon6 Cold start idle problem JDM b16b
i have a jdm b16b converted to 0bd1, in the morning when i start it,(cold start) i have to hold the rpm's at 1500-2000 for a few minutes, if i dont it will start and die. once warm it will run and idle just fine. any suggestions would be awesome!!!
thanks
Old Feb 11, 2011 | 09:12 AM
Default Re: Cold start idle problem JDM b16b
nothin??? lol
Old Feb 11, 2011 | 10:01 AM
EFPhilly's Avatar
IACV. FITV. Vacuum Leak.
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
search buddy! the search button is above your post!
Old Feb 11, 2011 | 10:44 AM
IACV Maybe, This motor has no FITV, vaccum is good
Old Feb 11, 2011 | 11:32 AM
EFPhilly's Avatar
IACV not maybe.
Old Feb 14, 2011 | 06:10 AM
STILL NEED HELP GUYS
Old Feb 14, 2011 | 06:16 AM
Mad-Mike's Avatar
Did you check the IACV? I remember the one morning I forgot to plug my IACV in and the only way to get the car running it to hold the rpms at 1500-2000.
Old Feb 14, 2011 | 06:19 AM
CrAzE191st's Avatar
Yea you need to either plug in your IACV or clean it out. I purposefully keep mine unplugged because its too dirty and I don't feel like doing the whole cleaning thing in cold weather since I don't have a garage. Theres nothing actually wrong here, if you're cool with revving it a little high for a few minutes than just clean it out whenever you get a chance or make sure its plugged in.
Also, if I'm not mistaken, if you have a JDM motor you might have to re-pin the connector. Someone please correct me if I'm wrong.
Old Feb 14, 2011 | 07:02 AM
EFPhilly's Avatar
Believe the IACVs are all the same minus the position of the bolt holes.
The OP asked for what to do...I as well as everyone else said IACV and you still say you need help. If you don't try what we tell you Im sure most will stop helping you out with this thread.
If you want help you have to take it as it comes...
Running a motor with no IACV is just ghetto. I dont see why you need a shop to clean out when it is so easy.
http://www.team-integra.net/sections...ArticleID=1174
The only thing that is hard about cleaning it is not spraying too much pressure into there because it will shoot up and out and get into your eyes, and that **** hurts!
ill try and clean it, it is plugged in tho. if i unplug it the CEL comes on.
Old Feb 14, 2011 | 07:05 AM
thanks for the link. will try it today and post results
omg_jdm
Feb 26, 2009 07:23 PM
black0hatch
Jan 22, 2008 08:55 PM
mjrino
May 16, 2007 04:28 PM
roterx7
Jan 19, 2007 07:14 PM
Apocolipse269
Jan 6, 2005 08:32 AM
