99 civic ex/b16 swap won't start
Old Feb 9, 2011 | 10:55 PM
bradabu's Avatar
Default 99 civic ex/b16 swap won't start
i have a 99 civic ex and i just swaped my motor and put a b16 it it. the problem is that it wont start. it has clean fuel, a good spark, good fuel flow out of injectors, good compression (165 psi). i tried two ecus, my sohc and a b series. its also have good timing, no leaks, good head gasket. it just doesnt want to turn over. all wires are connected except for knock sensor but my b series ecu is chipped and bypass that. grounds are tight, battery strong, but idk whats the problem...
any help will be nice, thanks
Old Feb 9, 2011 | 11:01 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: mechanic HELP!
recheck grounds.
Old Feb 9, 2011 | 11:17 PM
jdmadam's Avatar
clean all three of your grounds up real good with sand paper and try it again.
Old Feb 10, 2011 | 01:04 AM
hatchet_honda's Avatar
is the trans grounded? the neg battery cable should be attached to the trans at some point
Old Feb 10, 2011 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
Are you saying it won't start or won't crank?
Old Feb 10, 2011 | 08:20 AM
Dontoh's Avatar
yeah.. exactly what is your problem? you turn the key and what happens?
Old Feb 10, 2011 | 08:55 AM
Former User's Avatar
Default Re: 99 civic ex/b16 swap won't start
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Title edited.
Old Feb 10, 2011 | 11:55 AM
bradabu's Avatar
ill check the grounds, but my motor cranks, but no start. for example, its like starting a car with no gas, it will crank but not start, but my car has gas
Old Feb 10, 2011 | 03:48 PM
jdmadam's Avatar
Is your map and tps sensor plugs right? They have the same style connector and alot of people mix-match these plugs by mistake
Old Feb 12, 2011 | 07:50 PM
-__-'s Avatar
*this issue was resolved. his distributor was MISSING A WIRE. I spent a loooooong time trying to diagnose this car. the wiring on the distributor was messed up. the car runs now :D thanks for ur help.
Old Apr 21, 2014 | 11:04 AM
KPDSM's Avatar
sorry to bring back from dead but im hoping this is my issue too. my car ran as a stock lsv in 96 sedan with a turbo kit strapped to it. since i upgraded the fuel rail - it WONT START. Right when it seems like its going to turn over it doesnt, then starts cranking again. I hope a bad dizzy is the problem as I've literally been over EVERYTHING.
Old Apr 21, 2014 | 11:08 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
That sounds like incorrect firing order, a broken rotor driver, or a distributor installed 180 degrees off. Or wet/damaged ignition components.
Old Apr 21, 2014 | 11:09 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Start a new thread instead of bumping an old one.
Old Apr 21, 2014 | 11:24 AM
Technical Hero
So it only started after your fuel rail install? If so Id look there first, maybe the fittings on the fuel rail end differs from the stock one.
Old Apr 21, 2014 | 01:07 PM
KPDSM's Avatar
In all honesty, I'm hoping thats what it is. Thanks for your reply. We will know by thursday if thats it as I have a new dizzy on the way.
Old Apr 21, 2014 | 01:10 PM
KPDSM's Avatar
Hey HPH-
My buddy has the exact same rail on his car. He has 240s and a different FP gauge (i have 900s) but it all fit on exactly the same so I had ruled that out.
Old May 24, 2014 | 02:11 AM
KPDSM's Avatar
Bent rod. Cyl number two. No idea how because the day before it wouldn't start it ran fine. Anyway - blocks been removed...new swap got started yesterday.
Rexy15
May 6, 2016 04:05 PM
Win-dee
Apr 12, 2016 07:52 AM
b18cEK
21
Apr 6, 2011 03:15 PM
agent1471
Jan 12, 2011 04:37 PM
chenlenglor
Sep 18, 2009 07:33 PM
