Multiple codes, need ideas
A couple weeks ago the speedo in my 95 del sol started acting up. I figured no biggie probably the vss. Went to go drive it today after switching out the vss and still no speedo. After a bit the CEL pops up and I check it. Codes 6, 10, 17, 21, 23 are present. I'm wondering how they all relate. Common ground I need to check? Any ideas and where I should start?
Drove the car after ecu reset and still no speedometer. Drove 10 miles, stopped turned vehicle off for 30 minutes and drove 10 miles back. No cel present.
Nice not have any CEL codes, bad not to have a working speedo. The absence of a CEL, however, suggests that the speedometer or cluster is bad. Am I correct in assuming that the odometer and tripmeter also don't work?
No odometer and no tripmeter. Found a donor cluster from a friend and installed that yesterday. Same problems no speedo, no odo, and no trip. Code 17 is now present though which is a good thing. Somewhere to start. Do you have the diag tree for the vss?
hucoreyCRX
Jun 29, 2009 05:39 AM
