92 Honda LX Shifter Issue (manual)
Old Feb 8, 2011 | 10:38 PM
Smallboxx's Avatar
Default 92 Honda LX Shifter Issue (manual)
On my 92 Honda accord LX f22 stock powertrain i have about 2-1/2 to 3-1/2 inches of play forward and backwards on the shifter inside the car. I have traced it to the cables where they are attached at the trans. The cables outside of the transmission are working fine. The play is internally in the transmission. The two swing arms that the cables connect to are on a box that you can unbolt. Just want to know (1) if anyone has had this problem (2) has a solution (3) is there a chance if i take the swing arm 'box' off the trans to see what going on inside, is there a chance that something will fall into the transmission?
thank you Honda-tech world
smallz
Old Feb 10, 2011 | 10:24 PM
Smallboxx's Avatar
Default Re: 92 Honda LX Shifter Issue (manual)
bump for help
Old Feb 11, 2011 | 10:32 AM
Smallboxx's Avatar
final bump for this one to see if anyone knows anything
Old Feb 11, 2011 | 04:43 PM
phootbag's Avatar
Auto, manual?
Old Feb 11, 2011 | 06:30 PM
Smallboxx's Avatar
manual 5spd
Old Feb 12, 2011 | 03:16 PM
phootbag's Avatar
Are you certain the play is inside the transmission? Have you removed the shift cables from the transmission?
To answer your question, no. You can remove the piece you are talking about. You'll see how the levers contact the shift forks.
Make certain the play is actually inside the trans before you rip it apart.
Old Feb 12, 2011 | 06:17 PM
Smallboxx's Avatar
i have verified it is internal trans. ok thank phootbag
smallz
Old Feb 12, 2011 | 08:35 PM
phootbag's Avatar
By the way, did this problem develop slowly over time, suddenly or after doing work to the car? Just curious.
Old Feb 13, 2011 | 02:28 AM
Smallboxx's Avatar
had the car for e years and it always did it ... just getting worse
JGTW
Jan 8, 2019 07:58 AM
auzzie1998
Jul 8, 2017 04:40 PM
Candy Maniac
Honda Fit
Aug 28, 2015 09:16 AM
omgwtfbbqcrx
Apr 24, 2006 08:16 AM
