Suspension & Brakes Theory, alignment, spring rates....
will oem honda 15" wheels fit the type r front caliper
Old Feb 8, 2011 | 04:51 PM
blackccoupe's Avatar
Default will oem honda 15" wheels fit the type r front caliper
Will they fit the prelude rotor type r caliper uprade on my 99 civic
Old Feb 8, 2011 | 07:31 PM
roastbeefrichie's Avatar
Default Re: will oem honda 15" wheels fit the type r front caliper
yes, the 11" prelude rotor (re-drilled to 4X100) w/ ITR front calipers
will clear OEM 15" honda/acura 4X100 wheels
fat 5ive hammers
gsr blades
99-00 Si
integra meshes
Old Feb 9, 2011 | 03:46 AM
Ok cool and I use 92 - 96 prelude vtec rotors and 97 up type r calipers correct
Old Feb 9, 2011 | 07:14 AM
PreyStayShun's Avatar
fat 5ive hammers
gsr blades
99-00 Si
integra meshes
I used Legend two pot calipers (larger then R) & prelude rotors on my DC2 w/15" 96spec ITR wheels. It worked...and was f-in awesome.
As far as install, see:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-jdm-itr-4x114-3-brakes-onto-ek-811892/
Old Feb 9, 2011 | 07:24 AM
ROTORS
A. Prelude VTEC 11" front rotors, need to be re-drilled to 4X100.
* the 4th gen prelude is in a 4X114 pattern vs the 5th gen prelude, which is 5x114.
i prefer the 4th gen prelude VTEC, the 11" front rotors can be re-drilled cleanly, without overlapping
Quote:
Originally Posted by Dogginator
OP, there is no way possible to redrill a 4x100 pattern to a 5x114.3 without overlapping at least one hole. This is dangerous. I cringe when people redrill 282mm ITR rotors to a 4x100. (A 4x114.3 can be redrilled to a 4x100 without overlap.)
B. Fastbrakes SpecR Integra/Civic EX/Civic Si 11" Plain rotors for modified ITR 17CL15VN calipers
Product Code: FB DA/DC SPECR 11 INCH ROTORS $47.50 ea
http://www.Fastbrakes.com/product_p/...h%20rotors.htm
* the fastbrakes 11" front rotor in 4X100 saves you the trouble of re-drilling
the ITR caliper is stamped 17CL15VN
the 17CL15VN is one of the biggest single piston calipers honda produces.
you can easily identify this caliper from the stamp.
this caliper can also be found on:
97-01 ITR,
97-99 CL V6,
91-95 legend,
96-98 rl,
95-98 tl,
92-94 vigor,
95-02 accord v6,
91-97 accord wagon,
97-01 crv,
95-01 odyssey,
92-96 prelude vtec
& 97-01 prelude
Old Feb 9, 2011 | 11:18 AM
Will they still be stamped if iget them from a parts store
Old Feb 12, 2011 | 07:20 AM
Has anyone drilled the prelude rotors with a hand drill there is no machine shop near me and I think with a good bit it would work?
Old Feb 12, 2011 | 09:38 AM
i'm not saying it cant be done with a hand drill,
but for the sake of safety & accuracy, you'll want to re-drill with a drill press.
if there arent any machine shops in your area locally,
fastbrakes.com might be your best option for rotors.
your knuckle size determines your rotor size...
what size are your front knuckles on your 99 civic currently??
are they DX's or bigger knuckles (such as 99-00 Si or 94-01 integra)?
a. DX knuckles (9.4" front rotor stock) = ITR caliper/10.3" front rotor
b. 99-00 Si/94-01 integra (10.3" front rotor stock) = ITR caliper/11" front rotor
*also, since you are having trouble with rotors, just wondering how you were planning to install the ITR calipers...shims? machined brackets?
Old Feb 12, 2011 | 10:33 AM
I have ex 10.4 brakes already bought some Lude rotors and im gonna shave the necessary amount off the caliper bracket
Old Feb 14, 2011 | 05:59 PM
i reading mixed reviews does the caliper bracket need shaved or not some say yes some say no
if this is done correctly, there should be NO concerns
i have 98 crv calipers same as type r calipers
yes post #6 in this thread, 17CL15VN front calipers
so which one is it? you getting them mill'd or not???
i wantt o get them ready so i can just bolt them on but dont want to shcave the bracket if its not necessary
no, you can NOT just bolt them on
the problem is offset; once you install the rotors & attempt to install the brackets, the rotors will NOT spin because it'll get caught and binded.
you can solve this by:
A. milled brackets
B. shims (or spacers)
i prefer the machined brackets, shims can deteriorate over time from heat & wear
Old Feb 14, 2011 | 06:32 PM
thanks man i'll get them milled 3mm i thinkis what i read
Old Feb 14, 2011 | 06:41 PM
Originally posted by BrakeExpert,
Old Feb 17, 2011 | 04:23 PM
i got my rotors drilled now i gotta do the brackets anyone do it using a grinding disc or bench grinder im not paying 80 bucks for the machine shop to do it
Old Feb 20, 2011 | 02:36 PM
well they clear easily thanks for the help guys and u dont need to get the brackets milled i used a disc grinder and did them in 20 min
Old Mar 14, 2011 | 10:59 PM
Ej8_KiD's Avatar
97-01 ITR,
97-99 CL V6,
91-95 legend,
96-98 rl,
95-98 tl,
92-94 vigor,
95-02 accord v6,
91-97 accord wagon,
97-01 crv,
95-01 odyssey,
92-96 prelude vtec
& 97-01 prelude
is this info 100% correct? cause i can get some 95-98 tl calipers for cheap but i would like to know if they are the same as the ITR
Old Mar 16, 2011 | 03:37 AM
Dogginator's Avatar
Daisy... Daisy...
Pay the $80. I had the mounting face machines, which needs to be both flat and parallel to the rotor.
Old Mar 16, 2011 | 10:25 AM
I already did them used a hand disc grinder took about 20 I just kept measuring them with a digital measure came out perfect
hondur
Suspension & Brakes
13
Apr 1, 2016 11:00 AM
gsrboost737
Mar 23, 2009 11:00 PM
DAchiko
Sep 9, 2007 09:11 AM
Todd Reid
55
May 20, 2006 04:18 PM
teger
Apr 16, 2002 10:49 AM
