I'm working K20/K24 - What can u suggest better - over 8k$ budget
My engine is k20a Type R jdm
I bought a K24z3 accord 2008 with oil jet.
I'm going N.A. for time attack
Will do or buy :
ERL Performance Strocker Kit 102mm (+3mm) crank
Brian Crower rod ratio 1.5
Wiseco 12.5:1 89mm (+2mm) 94 octane fuel
Inlinepro sleeved
8lbs flywheel competition clutch
ssr header 4-2-1, 3''
obx itb 52mm
Supertech valve train +1mm oversize
Drag Cartel Cam stage 4
head optimized to 350 cfm
what do you think ? to sleeve a block because I want 89 bore, is-it a waste of money ?
if I change the crank, is that the gain in hp will be enough to justify the investment
my question is simple, I don't want spend 1500$ for a piece that the win will be 1 hp, may be 87 bore with 99 stroke is enough
Will do or buy :
Inlinepro sleeved
obx itb 52mm
obx itb will all of these high quality parts?
Its up to you...You want to be fast for a few year or for one season?
I have the RBC that I can oversized and polished
The reason why I choosen the OBX is because it's a external piece from the engine. So if something goes wrong, i will remove it and i will install my rbc
Anyway, I wondering what will be the difference in hp between the same kind of set-up without sleeve (bore to 87.5mm) and stroker crank (with oem).
if the gain is between 25-30 hp with a bore 89 and a stroker 102, it's a good choice. but if the hp gain is 5-10 hp, I will not do the investment.
this is for an all out time attack motor? with refreshing often (bearings & rings & maybe pistons)?
I'd ditch the stroker & sleeves for a good dry sump ($3,500)
no obx itbs
with those big cams & a lot of up shifts & down shifts look into Psi maxlife valvesprings/retainers/bases (often refered to as "indy springs" ) you can get them from/thru Team4piston or thru Hytech
get ready to open the wallet $1,000
all in all you are not $8K budget you're much more
what is the suspension set up in this car? what about a cage? transmission (dog box? sequential? or a few oem boxes rebuilt often?) any pics?
no obx itbs
get ready to open the wallet $1,000all in all you are not $8K budget you're much more
no obx itbs
no obx itbs
what is the suspension set up in this car? what about a cage? transmission (dog box? sequential? or a few oem boxes rebuilt often?) any pics?A major gain can be observed with e85 and over 13.0:1 c.r. instead huge stoke and bore
a K24 is allready stroked and get a similar dyno result with oem 87mm and 99mm
so now, will figure the following set-up with the K24z3 Accord oem block and crank :
Will buy :
bore oversized job (+0.5mm)
new connecting rod
new pistons 12.5:1 87.5mm (+0.5mm) 94 octane fuel
new cam gear
tuned and dyno
ACL bearing
APR head stud
of course new gasket
Crank balanced job
ERL s2000 oil pump
Toda chain tensionner
Will keep my
RBC instead ITB
BDL T.B. 74mm
Replyca Hytech Header
k20a-r head with all sensor, oil cooling, harness,
k20a-r computer, k-pro
My tranny have Kaaz lsd and Spoon F.D. 5.06:1
I think that this set-up will be in 280 wph range
Similar set-up from k20a.org
link : http://www.k20a.org/forum/newreply.p...reply&p=784861
12.5:1 c/r ratio wiseco deep relief pockets
ibspec h beam rods
acl rod bearings
stock headgasket
supertech valve train and flat valves
DRAG CARTEL STAGE 4 CAMS
650 cc injectors
Rbc intake manifold with stock 02-04 type s throttle body
hytech replica header
walboro fuel pump pump gas 91 octane
Tuned by Daniel (aka palmerblock) at church automotive testing
ibspec h beam rods
acl rod bearings
stock headgasket
650 cc injectors
build thread ... user using obx itb's
http://www.k20a.org/forum/showthread.php?t=81119&page=6
you just cant put obx and hayward or kinsler in the same sentence...If you cant afford to go itb the right way put a rbc on your car.
your saying that just cause your headers are made BY XXX brand now XXXkidd made a exact copy of Brand XXX Header they wont work cause it was copy by XXXkIdd...
just cause the material isn't the same as XXX BRand they are a total fail?
They maybe "cheap" but they WORK.... 10.8@126mph
http://www.youtube.com/watch?v=bjbs3...eature=related
hey
fuel ? e85 or methanol ?
hey
What type of setup is this.
from k20a.org
SET-UP #339
K24a1 (CRV) / K20a2 (Type S) Head + porting
K20a2 type s pump
Wiseco 87.5mm bore 13.7:1 C.R.
IB rods
Blueprint Racing Camshaft Stage 3 K Series i-VTEC
Blueprint Racing Valve Springs
Blueprint Racing Valves +0.5mm
Blueprint Racing Titanium Retainers
OEM crank
RBC + porting
BDL 70mm Throttle Body
SSR/DTR + Me***on
Power 339, torque 228 with E85
By Honda@racing
K20a2 type s pump
IB rods
OEM crank
RBC + porting
SSR/DTR + Me***on
By Honda@racing
SET-UP #321
K24 with 357 cfm
Cartel stage 4 cams
88.5mm bore with 99mm stroke with 13 C.R.
IPS manifold
DTR/SSR header
Power 321, torque 212 E85
by eg6k
K24 with 357 cfm
Cartel stage 4 cams
IPS manifold
DTR/SSR header
by eg6k
SET-UP #325
Benson Sleaved K24 with IB Ported K24a1 Vtec Killer
CP pistons 90mm bore with 13:1 C.R.
ASP Custom sheet metal intake manifold
Throttle Body 80mm
ASP 4-1 header w/megaphone
Power 325, torque 203
By Onefstek
Throttle Body 80mm
By Onefstek
SET-UP #310
K24a4 (Accord) block with K20 Head
AEBS sleeves
CNC port from Headway Performance
88mm Bore CP Pistons with 12:5:1 C.R.
Carillo A-Spec Rods
Skunk 2 Stage 3 cams
Skunk 2 Pro Series springs
Skunk 2 EX Cam gear
Skunk 2 valves
K-pro tuned
650 Injectors
IPS manifold
90mm accufab throttle body
DTR 4 into 1 Headers
3in Vibrant Ex & Res
Power 310, Torque 214 with 93 octane
By Jeff_16
AEBS sleeves
Carillo A-Spec Rods
Skunk 2 EX Cam gear
Skunk 2 valves
K-pro tuned
650 Injectors
IPS manifold
By Jeff_16
SET-UP #310
K24a1 (CRV) block + stock sleeves
K20a2 (Type S) pump
87.5mm CP piston with 12.5:1 C.R.
IB rods
OEM 99mm crank
Toda Racing Cams A3
Toda Racing Valve Springs
Skunk2 Valves
Skunk2 Titanium Retainers
RBC + porting
DC sport header
Power 310, torque 270 with euro 98
by Honda@racing
K20a2 (Type S) pump
IB rods
OEM 99mm crank
Toda Racing Cams A3
Skunk2 Valves
RBC + porting
DC sport header
by Honda@racing
SET-UP #305
K24a1 (CRV) block, IB spec K20a2 (Type S) Head
Skunk2 stage 3 cams
88mm bore pistons 13.7:1 C.R.
IB spec RBC with BDL 70mm T.B
SSR 4-1 with megaphone
Power 305, torque 220
By boostedGSR-SI
Skunk2 stage 3 cams
By boostedGSR-SI
SET-UP #289
K24a1 (CRV) block sleeved with K20a2 (Type S) ported head
Wiseco pistons 10.5:1 C.R.
Stock rods
Skunk 2 Stage 2 cams
Pro-serie Skunk 2 springs
Titanium retainers
Supertech dome valves
2006 SI intake with 3 inches cold intake line
3 inches K*N* air filter
Ventury throtle body
DC sport header 2.5’’
2.5’’ exhaust line with catalyst
Power 289, torque 192 on Dynapack
By Lagachette
Stock rods
Titanium retainers
By Lagachette
SET-UP #282
Drag Cartel Stage 4 cams
Wiseco deep relief pockets with 12.5:1 C.R.
IB spec H beam rods
ACL rod bearings
Stock headgasket
Supertech valve train and flat valves
650 cc injectors
RBC intake manifold with stock 02-04 type s throttle body
HyTech replica header
Power 282, torque 217 with 91octone and walbro
By xhadudkenx
IB spec H beam rods
ACL rod bearings
Stock headgasket
650 cc injectors
By xhadudkenx
SET-UP #281
K24a2 (TSX)
Stock head with Supertech valves and valvetrain
CP 12.5:1 C.R. 87.5mm bore pistons
IPS K10 cams
IB rods
TWM 52mm ITB's
SSR header
Power 281, torque 197
K24a2 (TSX)
IPS K10 cams
IB rods
TWM 52mm ITB's
SSR header
SET-UP #280
K24 with k20a2 (Type S) head
87.5mm bore x 99mm stroke with 12.5:1 C.R.
Drag Cartel 4's
Ported RBC
70mm t-body
Custom 4-1 header
Power 280, torque 195
by xcel
Drag Cartel 4's
Ported RBC
70mm t-body
Custom 4-1 header
by xcel
SET-UP #279
k24a4 (Accord) with stock K24a2 (TSX) head
Pistons 12.5:1 C.R. 87.5mm bore pistons
Rods aftermarket
K-pro tuned
Hytech Cams
Type S VTC gear
Supertech valve springs, valves
Titanium retainers
Hytech K24 header
RBC manifold
Power 279, torque 222
Rods aftermarket
K-pro tuned
Hytech Cams
Type S VTC gear
Titanium retainers
Hytech K24 header
RBC manifold
SET-UP #278
K24 with stock head
87.5mm bore Wiseco pistons with 12.5:1 C.R.
Blueprint H beam rods
Blueprint stage 3 cams
Blueprint spring & retainers
75mm T.B.
Ported RBC by Blue Print
Battle ground header
3" mandrel exhaust
Power 278, torque 207
By killa_k
K24 with stock head
75mm T.B.
3" mandrel exhaust
By killa_k
SET-UP #275
K24/K20 stock head
Wiseco pistons with 12:5:1 C.R.
Blueprint I beam rods
Brian crower stage 3 cams
Brian crower springs & retainers
BDL 70mm TB
RBC manifold
SSR header
3" exhaust
Power 275, torque 196
pump gas and on dynoPak
by Killer_k_All_day
K24/K20 stock head
BDL 70mm TB
RBC manifold
SSR header
3" exhaust
by Killer_k_All_day
SET-UP #275
K24a4 (Accord) block, K20a2 (Type S) stock head
Wiseco 87.5mm bore pistons with 12.5:1 C.R.
Connecting rods (IB spec) machined to be free floating
Type S oil pump
ACL race bearings RODS/MAINS
Fujita intake SRI
Kswap header (replica)
Header back HyTech exhaust (2.5in)
Twin loop HyTech muffler
Power 275, torque 210
By xhadudkenx
Type S oil pump
Fujita intake SRI
By xhadudkenx
SET-UP #272
K24 IPS block k20 head
12.5-1 C.R. pistons cunningham rods
Oversized supertech intake and exhaust
IPS KME 8620 cams
Kpro tuned
RBC intake
RC 550s
SSR coated 4-2-1 header
Power 272 @ 7800, torque 220 @ 5500
IPS KME 8620 cams
Kpro tuned
RBC intake
RC 550s
SET-UP #272
K24/k20 Stock head
Blue print I beam rods
Knife edge crank
Eibach springs and EVC springs
Bleu print Stage3 cams
RBC with 70mm T.B.
CAI 3 inch intake
550 injectors
Hytech copy header
AEM ems
Power 272, torque 196
tune it 2 weeks later put down 293hp 216tq
by K20_coupe
K24/k20 Stock head
Knife edge crank
RBC with 70mm T.B.
CAI 3 inch intake
550 injectors
Hytech copy header
AEM ems
by K20_coupe
SET-UP #271
K24 Geartech complete engine
Wiseco pistons
Blueprint rods
Golden eagle head studs
Golden eagle head gasket
Blueprintracing stage 3 cams
KMS valve springs and retainers
Unported head
Geartech ecu tuning
Toda tensioner
Manganese bronze valve guides
OEM bearings
RBC ported coated
Spoon throttle body
440 injectors
OBX header
3inch pmc exhaust
Power 271, torque 29 (metric)
By Toda275
Wiseco pistons
Blueprint rods
Unported head
Geartech ecu tuning
Toda tensioner
OEM bearings
RBC ported coated
Spoon throttle body
440 injectors
OBX header
3inch pmc exhaust
By Toda275
SET-UP #266
K24a4 (Accord) bottom end built by Blueprint
Aftermarket pistons with 12.5 C.R.
Aftermarket H beam rods
New Honda bearings through out
K20a2 (Type S) Head
Blueprint springs and retainers
RBC intake manifold
70mm BDL throttle body
(port matched the RBC to the Throttle body)
RC 550 injectors
ASP 3 inch exhaust
ASP 4-1 header with megaphone/reverse cone
Power 266, torque 192
By Timaa66
K20a2 (Type S) Head
RBC intake manifold
RC 550 injectors
ASP 3 inch exhaust
By Timaa66
SET-UP #264
K24a2 (TSX) head ported at 310cfm
Skunk2 stage 2 cams
Pro series Skunk2 springs
Titanium Skunk2 retainers
K pro tuned
CP pistons with 11.5:1 C.R.
Brian Crower rods ultra light
Balanced Crank
Hybrid Racing Tensionner
TSX block with Type S oil pump and Type S oil cooler
2.5 inches exhaust with catalyst (weak point for this set up)
DC sport header
410cc injectors
Power 264, torque 215
Skunk2 stage 2 cams
K pro tuned
Balanced Crank
DC sport header
410cc injectors
SET-UP #260
K24a2 (TSX) Bottom with K20a (Type-S) Head
IPS K2 cams + Eibach Springs + Titanium Retainers
Stock ports, Stock valves
11.7:1 C.R. pistons
Carrillo I beam rods
K-Pro tuned
52mm TWM ITBS w/ RC 440cc Injection
DTR 4-1 Header
Power 260, Torque 195
11.7:1 C.R. pistons
K-Pro tuned
DTR 4-1 Header
SET-UP #259
K24a4 (Accord)
Wiseco Pistons,
Eagle Rods (stock bore & stroke)
Skunk2 Camshaft
TWM ITB
Custom Fabricated Header with exhaust: 3"
Power 259, torque 190
By Hyperev
K24a4 (Accord)
Wiseco Pistons,
Skunk2 Camshaft
TWM ITB
By Hyperev
SET-UP #256
K20z3 (SI)
GO-Power KSi CAMS
GO-Power Ported IM
NST Pulleys
TSX oversized (68-70mm)
RDX Injectors
HONDATA IMG
SSR replica
GO-Power 3" exhaust
Flashpro power 256
Accesport 240whp (sans injectors, ported intake manifold, bored TB, and 3" exhaust).
RuloSI posted by Rulo
K20z3 (SI)
GO-Power KSi CAMS
GO-Power Ported IM
NST Pulleys
RDX Injectors
HONDATA IMG
SSR replica
GO-Power 3" exhaust
Flashpro power 256
SET-UP #254
K20Z3 (SI) stock bottom end
Skunk2 Stage2 Cams
Greddy E-manager
380cc Injectors
Supertech springs, retainers and Valve Stem Seals
CAI + AEM Filter
Header and exhaust Greddy
Dynomet Power 254 hp @ 9000 rpm
By Ewerton_cg
Skunk2 Stage2 Cams
Greddy E-manager
380cc Injectors
CAI + AEM Filter
By Ewerton_cg
SET-UP #253
K24a1 (CRV) block with K20a2 (Type S) head
12.5:1 C.R. (Nikos K20a.org spec)
IT R DC5 camshafts.
K-pro tuned
AEM CAI
RBC intake
SSR/DTR 4-1 header
Skunk2 cat-back
Feritta muffler
Power 253
By Asse
IT R DC5 camshafts.
K-pro tuned
AEM CAI
RBC intake
SSR/DTR 4-1 header
Skunk2 cat-back
Feritta muffler
Power 253
By Asse
SET-UP #252
K20a2 (Type S)
87mm Wossner pistons with 12:1 C.R.
Blue Print Racing i beam rods
New OEM bearings
Geartech ported head + manganese bronze valve guides
Blue Print Racing stage 3 cams
Skunk2 valves high compression
440 injectors
Skunk2 cat back 70mm
RBC ported
Skunk2 70mm throttle body
PLM header
Power 252, torque 24 (metric) on torque dynapack
By toda275
K20a2 (Type S)
New OEM bearings
440 injectors
RBC ported
PLM header
By toda275
SET-UP #252
K20a2 (Type S) Port & Polish stage 2
Crower stage 2: 3/4 Race Cams
Crower Stainless Steel Valves: Exhaust (30.5mm)
Crower Stainless Steel Valves: Intake (35.5mm)
Crower Valve Springs & Titanium Retainers
K24a1 (CRV Base)
Machined block, TSX oil Jet Squirters
Crower Maxi-Light Rods: K24A1
CP Pistons 12.5:1 C.R.
RSX type-s oil pump
DC Race headers (stainless steel)
2.5 inch custom exhaust line (stainless steel)
ITB TWM inductions 50 MM
Peak and hold injectors 660cc
Hondata Gasket
Power 252, Torque 167
K24a1 (CRV Base)
RSX type-s oil pump
Hondata Gasket
SET-UP #250
Stock k24a2 (Type S) with a 45 VTC
Stock Cams
Intake 2004 Accord with Type S TB
R Crew Header
3 inch exhaust, 3 inch truck Cat , Magnaflow Muffler
Dyno: Dynapack
Power 250 HP @ 7000rpm, torque 200 Ft-lbs @ 5000rpm
By Choo
Stock Cams
R Crew Header
Dyno: Dynapack
By Choo
SET-UP #246
Stock K24a2 (TSX) bottom, stock K24a1 head,
2004 TSX Ex cam,
CTR In cam,
RBC IM,
R-Crew V1,
Thermal 3" exhaust.
Power 246, torque 191
By TheMidasTouch
2004 TSX Ex cam,
CTR In cam,
RBC IM,
R-Crew V1,
Thermal 3" exhaust.
By TheMidasTouch
SET-UP #246
K20z1
Blue print stage 2 cams
R crew header
3 inch exhaust
Ported polished rbc
Modified stock injectors to 520cc
Velocity stack
Power 246 hp, torque 169 ft.lbs
By Benhondavtec
K20z1
R crew header
3 inch exhaust
Ported polished rbc
Velocity stack
By Benhondavtec
SET-UP #245
K24a2 (TSX) / K20a2 (Type S) stock internals
IPS KME Cams
Modified PRC intake manifold with 75mm throttle body
Custom 4-2-1 headers
2.5" full exhaust
Power 245, Torque 195
IPS KME Cams
2.5" full exhaust
SET-UP #240
K24 built block
CP pistons with 12.5.1 C.R.
BP rods
ACL bearing
Complete stock Z3 Si head
Power 240, torque 210
By jdmhatchturbo80
K24 built block
BP rods
ACL bearing
By jdmhatchturbo80
SET-UP #240
K24a4 (Accord) block with k20a2 (Type S) head
IPS k2's cam
Wisesco pistons with 12.5:1 C.R.
IB rods
K-pro tuned for 91 octane
DTR header
Power 240, torque 178
by gs4
IPS k2's cam
IB rods
DTR header
by gs4
SET-UP #240
K24a2 (TSX) block with k20a2 (Type S) head
RBC stock cams
Aftermarket pistons with 11:5:1 C.R.
Aftermarket rods
Ktuned intake
Hytech replica header
Thermal r/d 3inch exhaust
Power 240, torque 186
by Mel_ez
RBC stock cams
Aftermarket rods
Ktuned intake
by Mel_ez
SET-UP #240
K24a1 (CRV) block with K20A2 (Type S) head
BC Stage 2 cams
Supertech stock valves, dual valve springs, titanium retainers
RBC manifold
Karcepts Intake
Niko’s header
Power 240, torque 185
By Migs
BC Stage 2 cams
RBC manifold
Karcepts Intake
Niko’s header
By Migs
SET-UP #239
Stock Bottom End K20Z3 (08 Honda Civic Mugen SI #67)
Hondata Flashpro
Blue Print Stage 2 Cams @ 34 VTC
Supertech Springs & Retainers
Header: Kidd Dominator w/ 3" Test Pipe
Intake: AEM Cold Air Intake (Hollowed out MAF Plastic, on MAP via Flashpro).
Exhaust: 3" Mandrel to Apexi WS2 80mm Turbo Muffler
FIC 750cc Injectors
With E85 Walboro 255lph
Power 239, Torque 165
By Evil_genius
Hondata Flashpro
FIC 750cc Injectors
By Evil_genius
SET-UP #237
K24a2 (TSX) end K20a2 (Type S) head
3" CAI and BDL 70mm T.B.
Skunk2 Stage 2 cams
Skunk2 Pro-serie valvetrain
Exhaust cam gear retarted 3 notches
RBC with 70mm BDL T.B.
3" CAI
BCRH
70mm skunk2 exhaust
Power 237, torque 225
Skunk2 Stage 2 cams
3" CAI
BCRH
70mm skunk2 exhaust
SET-UP #236
K20A (Type R)
Toda Racing Spec N2
Supertech Titanium Valve Spring Retainers
R-Crew headers
Straight Pipe from Header to APEX'i N1 Muffler
TWM 52mm Individual Throttle Bodies
Lucas 310cc Fuel Injectors
Power 236, Torque 160
K20A (Type R)
Toda Racing Spec N2
R-Crew headers
SET-UP #235
K20a2 (Type S)
Toda 2.2 stroker kit (standard size pistons)
Unported head
Hondata K-pro
Toda a3 cams
Toda valve springs
RBC ported
68mm throttle body
Toda header
Custom 70 mm cat back
Power 260, torque 26 (metric)
By toda275
K20a2 (Type S)
Unported head
Hondata K-pro
Toda a3 cams
Toda valve springs
RBC ported
68mm throttle body
Toda header
By toda275
SET-UP #235
K20a2 (Type S) - Stock
Spoon head gasket
Blueprint racing stage 2 cams
Skunk2 valve springs
DC 4-2-1 header
Greddy 2 inch cat back
PRC intake manifold
Power 235, torque
by toda275
Spoon head gasket
DC 4-2-1 header
PRC intake manifold
Power 235, torque
by toda275
SET-UP #234
K24a2 (TSX) Long Block
50deg VTC
RRC IM
Hondata IMG
Hondata FlashPro
K20a (Type R) Flywheel
64mm TSX TB
Injen CAI
Go-Power "custom" SS K24 Header w/3" Collector
Full Race 3" Cat-Back Exhaust
RDX Injectors
Power 234 @ 7700 RPM, torque 190 @ 5400 RPM
By racingrhino
50deg VTC
RRC IM
Hondata IMG
Hondata FlashPro
64mm TSX TB
Injen CAI
RDX Injectors
By racingrhino
SET-UP #234
Stock K24a2 (TSX) bottom end
Stock K24a1 (CRV) head
Skunk2 Stage3 cams
RCrew Header
RBC
Power 262, torque 198
By TheMidasTouch
Skunk2 Stage3 cams
RCrew Header
RBC
By TheMidasTouch
Not a big deal man...For myself i like to buy from a compagny that have a real r&d team...A compagny that sponsor the drag/road race sport...I dont like to help these "fake parts people" to make money.
Few people like to buy cheap part and some want to help the legit compagny that's all.When you have problem with fake part you dont have any warranty on it so...
if you like obx then good for you man.I respect your choice
gsr336
Jul 25, 2006 07:32 PM
stale1 '01 itr 616
Aug 14, 2003 12:23 PM
