cam gear
Old Feb 8, 2011 | 04:05 AM
redright9's Avatar
Default cam gear
On a 1.5L non vtech 16valve, can the cam gear go on more then one way?
Old Feb 8, 2011 | 06:20 AM
Sonia's Driver's Avatar
Default Re: cam gear
No, it has a key built into the sprocket, as well as the splines to help it not wobble.
You *maybe* could turn it around and use it backwards, but then it would look backwards, you wouldn't be able to see the markings on it, and anyway, the camshaft is probably slightly tapered so it won't fit backwards.
Why do you ask?
Old Feb 8, 2011 | 08:31 AM
redright9's Avatar
I am trying to figure out why I cannot get my timing belt to line up and why I cannot get the ignition timing to set right. I always seem to be a half a tooth off, and when trying to set the ign. timing, Is like I cannot turn the distributer far enough ( I have jumped the two wires to set the timing). So, I was thinking maybe the gear got put on wrong.... It looks like just a stamped piece with little dimples in it to keep it from turning on the cam, but wasnt sure if they were spaced differently so it would only go on one way.
Old Feb 8, 2011 | 08:37 AM
grumblemarc's Avatar
The Grumpiest
This is the same problem as in this thread where people were already trying to assist you.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/timing-help-2894763/
Don't know why you started a whole new one.
Old Feb 8, 2011 | 03:40 PM
redright9's Avatar
Because it was a long day at work and thought about the cam gear and if it was able to be installed wrong.. Brain fart/lazy.
Ef4doorwagon
13
May 17, 2014 06:09 PM
ef-hatchcrap
Jan 25, 2008 12:45 PM
97grnrs
May 10, 2007 03:25 PM
DaNish
13
Jan 24, 2002 12:00 PM
