•RHD Conversion Info, Pics, Theory, Discussion Thread!•
Old Feb 8, 2011 | 02:05 AM
Dizzzle's Avatar
Default •RHD Conversion Info, Pics, Theory, Discussion Thread!•
Okay I know there used to be a write up on this a few years ago but the OP was edited and no one could see it. So I'm going start one up, Because I started my RHD conversion with basically no help or any info so I will make this to help others out. This is my first write up so give me a break and give me time to edit and change it around. Please post more Information or Corrections as I will update the thread to current and good info.
Please stay on topic as this is a information/pics thread.
Tool's
Corded Drill (Very Important)
Spot weld cutter/Drill bit (Very important, I prefer DRILL MASTERS Item #85343)
Flat head screw driver (Very Important, Also could use a air chisel)
Wire drill brush (Important used to take off seam sealer)
Plyers or vice grips (Important to pull metal back in some spots)
Welder (Any sort of welder will work, I prefer a MIG for this)
Information
Originally Posted by LVB18Civic
You can use just about any engine you want. RHD conversions are not for the faint of heart.
Originally Posted by jxh_28
ALL U NEED IS
RHD FIREWALL
RHD CABIN HARNESS UNDER DASH
RHD STEERING SUPPORT
RHD PEDAL/MANUAL/CLUTCH KIT
RHD SUBFRAME IS MORE IMPORTANT
RHD DASH
RHD HEATER CORE/AC
RHD STEERING COLUMM WITH KEY
RHD HOOD BOX/RELEASE
Many places sell rhd clips/conversion (here is a few)
tigerjapanese.com
hmotorsonline.com
passwordjdm.com
jdmcarboy.com
jdmshit.com
You don't need to remove the firewall shield (The extra layer of metal behind the firewall)
Originally Posted by E.Honda
Just another update on some electrical.
As for the horn.
When you do the swap you will no longer have an airbag (at least on the 92-95 civic) anymore.
You will notice 2 wires on the JDM harness on the headlight side of harness at the switch.
They will be red with a blue stripe.
If you have moved your headlight relay to the right side of the car it should be attached to the dash support that is attached to the right side of the body. You will notice that the wires are blue with green stripe, RED with BLUE stripe, black and white with a green stripe.
You can take 1 of your red with a blue stripe wires from your column and tap it into the same color wire at your relay and your horn should work. Be sure you have it plugged into the back of the steering wheel.
I just did mine tonite and it works fine with my momo steering wheel.
E.Honda
Originally Posted by xero_xero
you dont have to extend the blinker harness, but your blinkers will be reversed, so you will need to depin and swap the wires... you can trace the wire color to each one.
correct. flip your interior harness.
Originally Posted by Memo6453
For the a-pillar area its going to be different than some of the pics you see, basically take off all the seam sealer in that area where the firewall meets the pillar. Then you should see a few spots where you should drill out. Use the pictures for reference only and do not copy exactly what they did, these are from a few different builds I found during my build process. Some are tegs, eg6, ef's. Hope they help. If anything send me a pm or post the pics of your area and ill help you out.
Before with seam sealer.
After ground away.
Originally Posted by BrandonRyan
Hope some of these pics can help you guys out.
got the Jspec fire wall tore down.. with the help of the plasma cutter...
^Ignore the socks.. it was cold in the shop...
Now its time to prep all the areas.
Hopefully in a day or so i'll have more updates... This took 6 hours...
Somewhat of a quite of where you will be drilling
Originally Posted by saveacivic
anyone who actually has a rhd converted civic will tell you, there is no legal issue. not only is a converted rhd cheaper, there are no registration problems. why would anyone want a real one instead of a converted one? (uless its for the bling factor..) you are asking a million people who havent done it. ive done 4 over the years and NEVER had an issue. keep your stock motor, wiring and weld back the original vin. you will have no wiring, smog or legal issues.
Easily can be done in a month.
Swapping Vins
Originally Posted by relicwelding
Swap the vins. its the same car..just different firewalls hehe
Originally Posted by B18C5-EH2
I personally drilled the rivets out with s small bit and used new rivets to swap dashes with the two EFs I owned at the same time.
I had my red EF get t-boned so when I bought a white DX I swapped dashes and VIN plates before I sold the t-boned red EF with it's "new" blue dash. I did so to kep the VIN numbers matching.
Originally Posted by Crx Jimmy
use a 1/8 drill bit and drill the rivets out. Then use some new 1/8 rivets to re-install. It will look stock
Post pictures and other information that you think that should be added. I'm sure there is plenty that i'm missing. I also will add more in the afternoon and once I get my firewall out tomorrow or sometime this week Ill make a detailed diagram of which to drill and where to remove seam sealer.
Old Feb 8, 2011 | 02:15 AM
BlueIntegraBoy's Avatar
Default Re: RHD Conversion Write up Thread!
It is informative, but I didn't like how you just copy and pasted other write-ups. Once you do yours, you should only have yours in here.
Old Feb 8, 2011 | 02:18 AM
Dizzzle's Avatar
It's only to help out others, many write ups are used with quotes from others. I will be posting my photos along in this thread and diagrams and the techniques I used during my conversion when I get time. The write up is only to help others.
Old Apr 3, 2012 | 06:27 AM
teggyturborunna's Avatar
Default Re: •RHD Conversion Info, Pics, Theory, Discussion Thread!•
Any updates and/or pics??? In process of doing rhd on my da9 integra
Old Apr 3, 2012 | 09:46 PM
Arthas's Avatar
Its not 2005 anymore.
Old Apr 3, 2012 | 10:00 PM
Deetz's Avatar
Crazy Honda Guy
what a lot of work for nothing
I bought my last 94 del sol, a real rhd for $1400, i would never spend time converting a car that way, not worth it
Old Apr 4, 2012 | 04:28 AM
Yea it was a shot in the dark... And that's cause your in Canada! Lol it's not so easy to buy/find a true rhd in the states. It is a lot of work, but keeps me out of trouble lol and a good learning experience with fab and welding etc
Old Apr 4, 2012 | 05:36 AM
Deetz's Avatar
Crazy Honda Guy
Do you realize that in Canada, even though we have a rhd here and there, that they are looked down apon. People are always bitching about how dangerous they are to drive on our roads......they are worth much less than the left hand drive versions of the same car
Old Apr 17, 2012 | 05:30 PM
slammedg2's Avatar
bumpppp lets get some more info on the wiring >> building a da6 check my build thread out thanks
Old Nov 20, 2013 | 03:05 PM
wwcrxww's Avatar
i like how you put the thread together.....just wish you added your project from start to finish.... as well as what you already have posted
Old Nov 20, 2013 | 09:45 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Subscribed, but only because some day I might want to convert a JDM RHD into LHD. Stupid RHDs on LHD roads.
Old Nov 20, 2013 | 09:49 PM
jbpnoman's Avatar
You subbed to a 2 year old thread that should be dead. It isn't going anywhere.
downgrade
Jul 29, 2011 08:11 PM
SinsEvil666
15
May 15, 2008 12:34 PM
DC2 Mang
May 31, 2006 08:03 AM
rufrdr
Jun 29, 2002 09:56 PM
