99 Si cylinder head plug replacement? Help?
Old Feb 7, 2011 | 10:35 PM
05foresterxt's Avatar
Default 99 Si cylinder head plug replacement? Help?
I've been able to fix most of the oil leaks that my 99 Si had. I've now noticed that there is a leak on the cylinder head plug. This is a plastic plug that is located right next to the VTEC solenoid on the passenger side of the head. Does anyone know how to replace this and point me in the right direction? Thank you.
Old Feb 7, 2011 | 10:42 PM
beeseeries's Avatar
Default Re: 99 Si cylinder head plug replacement? Help?
Picture?
Old Feb 8, 2011 | 07:07 AM
dpetro1's Avatar
this is commonly known as the b-series cam seal. there are many aftermarket aluminum replacements. or the oem version is plastic
here's a link to the install
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-b-series-cam-seal-replacement-2414973/
golden eagle - $23.95
http://www.goldeneaglemfg.com/index....ex&cPath=76_96
oem part# 12513-P72-003 - $5.24
http://www.hondapartsunlimited.com/i...&submit=submit
Old Feb 8, 2011 | 07:46 AM
Former User's Avatar
https://honda-tech.com/forums/showthread.php?t=2414973
Nice. Link added to FAQs sticky.
Old Feb 8, 2011 | 07:50 AM
Em1LuiSiR's Avatar
every b16 ive owned has always leaked.
Old Feb 8, 2011 | 08:08 AM
dpetro1 - Thanks a million. Read the write up, just have a question. What should the two bolts from the cam cap be retorqued to?
Also, how much better are the aftermarket items compared to the OEM one? I mean, my car has 130k miles, so that means that this oem seal has lasted this long. So I would assume that replacing it with the OEM once should last another 100k more miles.
Old Feb 8, 2011 | 08:14 AM
AlexBerg's Avatar
Get the seal from honda, dont use and aftermarket one. The factory plug just pops in... the ones sold online are like the old style seals, and require taking the valve cover off and removing the cam cradles and all that stuff out to put in the seal.... its not hard at all to do and its like 10 or 15 bucks from honda.
Old Feb 8, 2011 | 08:18 AM
AlexBerg- Are you saying that with the OEM one, you can just pop it out and pop in the new one? I don't see how this can be done since the seal is flushed and there is nowhere to grab onto. Can you provide a little more info?
Old Feb 8, 2011 | 11:58 AM
dpetro1's Avatar
this is incorrect. you cannot simply "pop out" the seal. there is a lip on both ends of the seal so it would pretty much be impossible to push it through. if you were able to manage, im sure the seal would be damaged/destroyed completely.
you can see the lip on the oem and aftermarket here
OP, cam caps get torqued to 7.2 ft/pounds
Old Feb 8, 2011 | 12:11 PM
Besides not being plastic, what's the difference between the aftermarket and oem one? Also, would the oem one hold up to another 100k+ miles? If so, I don't see a need to go aftermarket. Thanks again dpetro1, I'll buy a small torque wrench and will be doing this myself
Old Feb 8, 2011 | 12:56 PM
dpetro1's Avatar
oem is fine. if the first one lasted this long then a new one should work just as well.
advantage to an aftermarket is that the aluminum doesnt wear over time like plastic. and they can simply be re-o-ringed if needed. for people that have the motor apart often, this may be an advantage. also there is a bit of bling factor with a billet aluminum piece. lastly, its a way for companies to make a quick buck by charging 4-5 times what an oem piece costs.
Old Feb 8, 2011 | 01:12 PM
thanks for all the info, OEM it is
ribal_gh
Feb 18, 2014 07:41 AM
SimpleAznMan
Honda Civic (2001 - 2005)
Mar 11, 2010 01:07 AM
hatchet_honda
29
Dec 20, 2009 09:57 PM
Cruzan77
May 10, 2009 08:06 PM
2ndGenGuy
Classic Hondas
Mar 18, 2009 07:11 AM
