Where to buy a slave cylinder bracket?
Old Feb 7, 2011 | 09:52 AM
mick54683's Avatar
Default Where to buy a cable trans with a hydro conversion bracket? (ys1)
Hey guys i recently bought i b18b1 swapped honda civic. Everything is great just i have to press my clutch to the floor and it still barely lets go. i found the problem and its the clutch slave cylinder mount it looks like someone welded together thier own one, which is not in the proper posistion to fully disengage the clutc . does anyone know where i can purchase a b18b1 clutch slave cylinder mount? and don't worry i know forsure its the problem.
Old Feb 7, 2011 | 10:05 AM
app's Avatar
app
Default Re: Where to buy a slave cylinder bracket?
I would probably try a junk yard first off and if not you can always buy a new online. acuraautomotiveparts.org
Old Feb 7, 2011 | 01:21 PM
mouab18c1's Avatar
A slave cylinder is mounted onto the transmission. I have no clue about the bracket you are asking about.
Old Feb 7, 2011 | 01:56 PM
egsleepercivic's Avatar
unless you have a cable trans with a hydro conversion there is no bracket, the slave bolts directly to the transmission housing on a hydro trans with 2 bolts, take a pic if you are not sure what you got
Old Feb 15, 2011 | 08:20 PM
mick54683's Avatar
I looked at it further and i have the ys1 transsmission i could only tell because of the shift fork. where can i find the proper slave cylinder bracket for this transmission?
Old Feb 15, 2011 | 08:24 PM
mick54683's Avatar
and yes its a cable trans with a hydro conversion. does anyone know where i can find the proper conversion bracket?
Mark Segree
Honda Civic (2001 - 2005)
Feb 17, 2016 04:14 AM
95_Civic_4dr
Feb 11, 2011 04:17 PM
Christopherian1982
May 25, 2009 08:10 PM
TuwboBuddy
May 3, 2006 07:40 PM
jon_
Jul 21, 2003 09:07 PM
