'HELP' car smokes like hell
Old Feb 7, 2011 | 04:39 AM
Built4Battle's Avatar
Default 'HELP' car smokes like hell
I got a LS VTEC with a b16 head
car smokes worse than seafoam
but it only smokes under load past 3000
doesnt smoke when i rev to like 7000 doesnt smoke when i down shift to high rpm
spark plugs look just fine oil/coolant not really disappearing much
no funny sounds
the smoke looks mostly white maybe just a little hint of blue
i dont even gotta hold the gas pedal halfway for it to fill up the whole street with smoke to the point it looks like heavy fog
thanks alot to the person can help me or went through this before
Old Feb 7, 2011 | 06:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: 'HELP' car smokes like hell
White smoke = head gasket. 94
Old Feb 7, 2011 | 06:23 AM
ciaran_mo's Avatar
blue smoke = piston rings.
Old Feb 7, 2011 | 08:12 AM
hatmanafro's Avatar
check for the head gasket. cuz that dosent sound good at all. lol
Old Feb 7, 2011 | 08:27 AM
PreyStayShun's Avatar
I'm with FCM and Hat,
OEM head gasket FTW!
Old Feb 7, 2011 | 08:44 AM
hatmanafro's Avatar
put some stop leak on that ****. itl be aight. hahaha
Old Feb 7, 2011 | 09:13 AM
geetee74's Avatar
that definitely doent sound healthy at all. Im gonna hve to agree with the crew. Headgasket FTW!! get it block tested for combustion gases in the coolant
Old Feb 9, 2011 | 08:54 AM
Red-Rag-B18's Avatar
I had the same problem once and damn its sad to see.
change your Headgasket, and if that don't work then yeah definitely check your piston rings, but most likely its your headgasket
Old Feb 9, 2011 | 02:28 PM
thanks
i was thinking the person who put it together might've put wrong head gasket on
you suppose to use the head gasket for the block right?
jeresaur
Mar 13, 2011 05:00 AM
caliEG2dr
May 15, 2010 12:44 AM
white_ej6
17
Feb 8, 2010 09:14 PM
lcsej1
26
Feb 17, 2009 09:30 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
