problems with d15b + d16a1 pistons
on paper everything should be clear
when i tried to put them on, i dont have piston clearance, it will obviously hit the head,
any clue?!
any clue?!
I guess, why are you using those pistons? And what paper are you reading off of? Mind you I know nothing about swapping pistons so these are just the questions I would ask.
but alot of people is doing this swap, i used 134mm rods just to get it right, d15 and d16 crank and rods, are they the same?
Use Google next time.
http://www.ht-archive.com/showthread.php?t=827359
It CAN be done, but you'll need the right parts.
If memory serves correctly you'll need D15B VTEC (JDM engine) or USDM 92-95 Civic VX rods to make this work. Keep the 1.5L crank too.
WHICH "D16A1" pistons are you running?
There are two different types. 86-87 "flat top" PG7, and 88-89 "crazy +7.2cc domed" P29 pistons. They yield entirely different compression ratios.
What head are you running?
What camshaft?
CR can either be "not ideal for street use" or "just fine provided your tune is good, and you use premium fuel."
I had "P29" highest-domed D16A1 pistons in an otherwise stock D16A6, and it was a bad-*** running set-up. Lots of fun, and cheap.
What camshaft?
98.4DR.EK.D16
Dec 15, 2012 03:30 PM
Jeanious
Dec 4, 2007 12:41 PM
shanepa2001
Jun 29, 2006 03:12 PM
