Burned Wire Harness
My right headlight works on high but not on low. i was replacing the bulbs and realized that the plastic wiring harness (is that the right term?) around it, had burned. so now i realize i need to replace the plastic wire harness that the wires go into that plugs into the headlight. what's that called, and does it cost a lot as an aftermarket part?
